gordy07 Posted December 23, 2008 Share Posted December 23, 2008 There was a squeeling sound coming off my car when i was driving about town. I doesnt happen on idle but in between 2-3k RPM its almost like a drive belt or fan belt sound. I noticed it the other night when i had heaters,lights and heated screen on so i thought it was just because it was under so much load. But today i had nothing on and its still doing it:( Any ideas? Link to comment Share on other sites More sharing options...
ClaireRZ-S Posted December 23, 2008 Share Posted December 23, 2008 I have the same thing at the moment not sure what it is but seems to happen when the car is cold when i drive it for awhile cant hear it Link to comment Share on other sites More sharing options...
gordy07 Posted December 23, 2008 Author Share Posted December 23, 2008 It might be the same thing Claire,i also noticed that when i stopped the car and revved it the noise was away:blink: Link to comment Share on other sites More sharing options...
Jamesy W Posted December 23, 2008 Share Posted December 23, 2008 Perhaps a dodgy turbo? Maybe a belt tensioner or something along those lines. Link to comment Share on other sites More sharing options...
gordy07 Posted December 23, 2008 Author Share Posted December 23, 2008 Perhaps a dodgy turbo? Maybe a belt tensioner or something along those lines. lol,i thought maybe that mate but i was wanting other opinions(serious ones) Link to comment Share on other sites More sharing options...
Dnk Posted December 23, 2008 Share Posted December 23, 2008 The auxilary belt could be slipping Link to comment Share on other sites More sharing options...
Dnk Posted December 23, 2008 Share Posted December 23, 2008 (edited) Check the power steering fluid, if thats low it can make the pump squeel Edited December 23, 2008 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
gordy07 Posted December 23, 2008 Author Share Posted December 23, 2008 The belt was changed about 10k miles ago(not by me)and this noise has just started. Is there a way to check if its tight enough? Link to comment Share on other sites More sharing options...
gordy07 Posted December 23, 2008 Author Share Posted December 23, 2008 I will check the power steering fluid too dnk cheers mate Link to comment Share on other sites More sharing options...
Dnk Posted December 23, 2008 Share Posted December 23, 2008 Could also be as said the tensioner, if you pop the bonnet it and run the engine it should be quite obvious if its the aux belt squeeling Link to comment Share on other sites More sharing options...
mike_mcevoy Posted December 23, 2008 Share Posted December 23, 2008 I've just had that, had to replace the Aux belt and crank pulley as it was starting to come apart. Link to comment Share on other sites More sharing options...
gordy07 Posted December 23, 2008 Author Share Posted December 23, 2008 Could also be as said the tensioner, if you pop the bonnet it and run the engine it should be quite obvious if its the aux belt squeeling When i got back to the house the noise had stopped it only seems to do it when im driving Link to comment Share on other sites More sharing options...
gordy07 Posted December 23, 2008 Author Share Posted December 23, 2008 I've just had that, had to replace the Aux belt and crank pulley as it was starting to come apart. God that sounds expensive,although the belt is only 10k old Link to comment Share on other sites More sharing options...
Dnk Posted December 23, 2008 Share Posted December 23, 2008 When i got back to the house the noise had stopped it only seems to do it when im driving Typical Link to comment Share on other sites More sharing options...
gordy07 Posted December 23, 2008 Author Share Posted December 23, 2008 Typical I know tell me about it:D Link to comment Share on other sites More sharing options...
Chrisbeast Posted December 23, 2008 Share Posted December 23, 2008 I had this on start up but went away after about 5-10 mins. I got some Silicone spray from Halfords and sprayed the belt whilst its was running. Noise has now gone completely! Take care not to loose your hand in the fan though. Link to comment Share on other sites More sharing options...
Dnk Posted December 23, 2008 Share Posted December 23, 2008 I had this on start up but went away after about 5-10 mins. I got some Silicone spray from Halfords and sprayed the belt whilst its was running. Noise has now gone completely! Take care not to loose your hand in the fan though. Id rather check why its making the noise as theres got to be a reason. Link to comment Share on other sites More sharing options...
mike_mcevoy Posted December 23, 2008 Share Posted December 23, 2008 (edited) God that sounds expensive,although the belt is only 10k old It wasnt too bad actually, got the expensive bits from Nic and got everthing replaced in one go, my belts looked fine to be honest but had both the timing and aux belts changed at the same time as it all has to come off anyway. Have a search on here for squealing and startup and you should find a lot (well I did anyway) I had the same thing when it got warm it quietened down, I wouldnt ignore it or hide it with silicone spray as it will get expensive.... Its worth checking this thread to check your crank pulley, hopefully it isnt that. Crank Pulley also this one Edited December 23, 2008 by mike_mcevoy (see edit history) Link to comment Share on other sites More sharing options...
gordy07 Posted December 23, 2008 Author Share Posted December 23, 2008 So would i dnk Link to comment Share on other sites More sharing options...
gordy07 Posted December 23, 2008 Author Share Posted December 23, 2008 It wasnt too bad actually, got the expensive bits from Nic and got everthing replaced in one go, my belts looked fine to be honest but had both the timing and aux belts changed at the same time as it all has to come off anyway. Have a search on here for squealing and startup and you should find a lot (well I did anyway) I had the same thing when it got warm it quietened down, I wouldnt ignore it or hide it with silicone spray as it will get expensive.... Its worth checking this thread to check your crank pulley, hopefully it isnt that. Crank Pulley I will do mike thanks for that:) Link to comment Share on other sites More sharing options...
gordy07 Posted December 23, 2008 Author Share Posted December 23, 2008 Looking at that video of crank pulley death wobble,thankfully its not doing that everything looks tight and solid. Im just going to pick up my wife soon so i will update shortly:) Link to comment Share on other sites More sharing options...
gordy07 Posted December 23, 2008 Author Share Posted December 23, 2008 I just went to pick up the wife and the noise has mysteriously gone but i will be inspecting it further tommorow in the daylight. Thanks for the help folks:) Link to comment Share on other sites More sharing options...
