Guest suprabass Posted December 22, 2008 Share Posted December 22, 2008 As the title says Im looking for a 60mm vband flange for a wastegate to weld to a manifold that ive got Quote Link to comment Share on other sites More sharing options...
Steve Posted December 22, 2008 Share Posted December 22, 2008 Why not post in the 'Wanted Section' then? Quote Link to comment Share on other sites More sharing options...
Guest suprabass Posted December 22, 2008 Share Posted December 22, 2008 Because Im guessing it would be a technical question "can you get such a thing"?? Quote Link to comment Share on other sites More sharing options...
Steve Posted December 22, 2008 Share Posted December 22, 2008 Which wastegate is it for? Quote Link to comment Share on other sites More sharing options...
Guest suprabass Posted December 22, 2008 Share Posted December 22, 2008 Hks gt2 Quote Link to comment Share on other sites More sharing options...
legendswraith Posted December 24, 2008 Share Posted December 24, 2008 You can get them but would not know eho manufactures them I'll keep an eye out at work there may be some off the engines it will be hacksawed off a pipe if i find one though. When you say 60mm i take it the 60mm is the diameter of the bore or the od of the flange? Wont you need both sides though as v band flanges mate into each other with a metaseal in the middle. If the wastegate has a vband flange on it which side is it? Quote Link to comment Share on other sites More sharing options...
