HERBIE Posted December 21, 2008 Share Posted December 21, 2008 Does anyone know if it is a very complicated job to get this setup done? I've decided to keep my mr2 now as after gettin a better ecu for it its runnin like a dream now that the boost comes online soo much earlier the stock brakes are rubbish and really want to upgrade,and think the UK Supra setup would be a good setup to have but not sure how much modification etc is required Can anyone help me out on this? thanks Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted December 21, 2008 Share Posted December 21, 2008 Anythings possible with the right amount of money... Get some caliper mounts made up, discs, bigger wheels. Is it the front or rear wheels on the MR that foul the shocks if theyre too big? I cant remember. Cant IMOC help? Quote Link to comment Share on other sites More sharing options...
HERBIE Posted December 21, 2008 Author Share Posted December 21, 2008 Anythings possible with the right amount of money... Get some caliper mounts made up, discs, bigger wheels. Is it the front or rear wheels on the MR that foul the shocks if theyre too big? I cant remember. Cant IMOC help? Have a set of EBC grooved and drilled discs ordered and have a set of deep dish 18's off me Supra that will fit with some suspension adjustments,no sure to be honest about the shock issue as i've not had the car long and still reading up on them IMOC,that some sort of Owners club? Quote Link to comment Share on other sites More sharing options...
Dave17 Posted December 21, 2008 Share Posted December 21, 2008 IMOC is THE owners club for MR2's matey, imoc.co.uk, they have done pretty much everything that can be done to MR2's. I always found mr2oc.co.uk to be pretty helpful as well. Quote Link to comment Share on other sites More sharing options...
HERBIE Posted December 21, 2008 Author Share Posted December 21, 2008 IMOC is THE owners club for MR2's matey, imoc.co.uk, they have done pretty much everything that can be done to MR2's. I always found mr2oc.co.uk to be pretty helpful as well. Cheers Dave.have joined mr2oc already,didnt even know about the IMOC.will register now Quote Link to comment Share on other sites More sharing options...
lockys96 Posted December 21, 2008 Share Posted December 21, 2008 huxracing sell the front caliper bracket to mount supra front brakes Quote Link to comment Share on other sites More sharing options...
HERBIE Posted December 21, 2008 Author Share Posted December 21, 2008 huxracing sell the front caliper bracket to mount supra front brakes thanks mate Quote Link to comment Share on other sites More sharing options...
johnny g Posted December 21, 2008 Share Posted December 21, 2008 Cheers Dave.have joined mr2oc already,didnt even know about the IMOC.will register now For inventive solutions, try TwoBrutal too Quote Link to comment Share on other sites More sharing options...
Guest dangerousandy Posted January 2, 2009 Share Posted January 2, 2009 I think I saw somewhere that ST205 GT-Four brakes fit the MR2 SW20....... Quote Link to comment Share on other sites More sharing options...
Nodalmighty Posted January 3, 2009 Share Posted January 3, 2009 I think I saw somewhere that ST205 GT-Four brakes fit the MR2 SW20....... I dummied up a set of MKiii turbo disc at 305mm on mine (Rev2 on fronts). You will need to remove the dust guard, back space the disc 5mm (as they are thinner discs) and have an adaptor made to move the stock calliper out the difference radially. With a set of CarboTec pads all round you will be doing endo's. However, an MR2 has a very fine front to rear brake balance so you will need a proportional valve in the rear line to correct this or you will be locking the fronts up all the time or p1ssing the ABS off. Lyndon. Quote Link to comment Share on other sites More sharing options...
