Flickering HID
ellis
Ellis,
I had mine do exactly the same. It turned out to be the power connection on the balast which had built up some deposits due to it's exposure to water where it had been mounted. Also, check that the condition of the connectors and the fuse on the relay.
Cheers mate - will do that shortly!
Just driving into work and the driver's side HID light starts flickering away. No loose connections that I can find. Is this the bulb on its way out or the HID pack itself?
Thoughts anyone?
I had the same problem with mine, it turned out to be the ballast, some water had seeped into it through a very small crack. I sent the faulty ballast back which was replaced very quickly :)
I have 2 hid kits in my supra, the same thing started happening to me one day, what the
cause of the problem was, one of the hid boxes was after coming off its bracket and
was lying up against the other box and was causing an interfarence with it. Just moved
it away and problem was sorted
