ajazyasin Posted December 18, 2008 Share Posted December 18, 2008 Im currently wiring in a link G4 storm to my 1jzgte soarer. I was hoping some of the more electronically minded amounst us could help as it is very similar to the 2jz supra. 1. The crank position sensor(Ne-, Ne) and cam pos sensor(G1-,G1) run 2 pins each on the factory loom. Which would be used as the trigger and which as the +8volt out on the standalone? 2. The factor loom runs all 6 injectors from 3 pins(#10,#20,#30). Im presuming this can wire into three of the G4s injection pins? 3. the TPS(Primary throttle) has 2 pins. VTA1 & IDL1. Which would be power? thanks in advance all. I just need to get the thing wired in and then it can leave my hands! Quote Link to comment Share on other sites More sharing options...
Nodalmighty Posted December 18, 2008 Share Posted December 18, 2008 (edited) Im currently wiring in a link G4 storm to my 1jzgte soarer. I was hoping some of the more electronically minded amounst us could help as it is very similar to the 2jz supra. 1. The crank position sensor(Ne-, Ne) and cam pos sensor(G1-,G1) run 2 pins each on the factory loom. Which would be used as the trigger and which as the +8volt out on the standalone? 2. The factor loom runs all 6 injectors from 3 pins(#10,#20,#30). Im presuming this can wire into three of the G4s injection pins? 3. the TPS(Primary throttle) has 2 pins. VTA1 & IDL1. Which would be power? thanks in advance all. I just need to get the thing wired in and then it can leave my hands! That is SO going to go pop if you wire it like that chap 8v is for Bosch MAF units. Ne goes to Trig 1 G1 goes to Trig 2 Ne- and G1- go to sensor ground. Vta1 goes to the TPS, VC goes to 5v and the other is sensor ground. ID1 is the idle switch, you don't need that one. Wire the Injectors #10,#30,#50 to INJ1 and #20,#40#60 to INJ2 as you can't use a three channel mode setup on a Storm. Set them as Grouped on INJ1 & 2. Wire the Ign1,Ign6 to Ignition1, Ign2,Ign5 to Ignition2 & Ign3,Ign4 to Ignition3 on the Link. Wire the Stepper motor Idle 1 to link aux5 Wire the Stepper motor Idle 2 to link aux7 Wire the Stepper motor Idle 3 to link aux6 Wire the Stepper motor Idle 4 to link aux8 The rest is quite straight forward. Good Luck If you are still struggling, [email protected] Lyndon. Edited December 18, 2008 by Lyndon @ Rogue (see edit history) Quote Link to comment Share on other sites More sharing options...
ajazyasin Posted December 18, 2008 Author Share Posted December 18, 2008 (edited) you are superb mate! you have mail:) Edited December 18, 2008 by ajazyasin (see edit history) Quote Link to comment Share on other sites More sharing options...
johnny g Posted December 18, 2008 Share Posted December 18, 2008 He's not bad is he!? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 19, 2008 Share Posted December 19, 2008 Reckon he's done one before ? Quote Link to comment Share on other sites More sharing options...
adnanshah247 Posted December 19, 2008 Share Posted December 19, 2008 i seriously thought you were asking about a mac G4. and was about to say Robert on this forum is your man. i must start reading threads properly. Quote Link to comment Share on other sites More sharing options...
ajazyasin Posted December 19, 2008 Author Share Posted December 19, 2008 Reckon he's done one before ? he's really saved me so much headache you cant imagine. Great member! Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 19, 2008 Share Posted December 19, 2008 Great member! That as well? Blimey Quote Link to comment Share on other sites More sharing options...
