Clunking Diff...
heckler
More description please, I would say it may not be hub bearings. Diffs are normally bullet proof unless James P is driving ;) One for you, are the stock LED's in the dash removable easily? Got a car here where the heater knobs need a push sometimes to get the lights on, and the A/C button LED doesn't light at all. Cheers.
Ok, if i drive forwards in any gear, no noise - works as advertised. come to a stop, engage reverse, clutch out and get a big clunk when moving backwards only, however if i put the clutch in or put into neutral while moving backwards, noise goes away. And as i discovered today, doesnt always do it!
Yes, LED are quite easy to remove/replace - http://www.internetwork.org.uk/led/led.htm no idea where you could get replacements from, but more likely to be a dry joint.
mine does this & sometimes when i set of i get a vibration which judders side to side from the box just behind the centre console thought it might be the donut mines a non turbo with limited slip where can you get them from & are they hard to fit or is it a full shaft job
I don't know if it's even possible on the MKIV, but if someone was daft enough to fit the centre bearing upside down, so the prop had an angle in the mid joint, I am sure it wouldn't like it, and it would cause a judder. the centre bearing SHOULD be atop the mounting, up in the tunnel, not lower down. Next time I do a clutch I'll see if it's even possible to fit it upside down, it may just be so....
  • 2 weeks later...
