Welders / gas bottle experts??
Chris Wilson
I want to be able to internally purge stainless pipe fabrications, but
can't justify hiring two full size bottles. Can you buy an adaptor to
run two regulators off one full size Argon mix bottle? One to run the
TIG and one with desperate pressure control, to purge the fabrication? If such a thing is made
does anyone knows who sells such a thing? Thanks.
yes this is the "Y" this comes off your guage
http://cgi.ebay.co.uk/3%2F8-BSP-Y-PIECE-WITH-VALVES---RH-THREAD_W0QQitemZ310105297225QQcmdZViewItemQQimsxZ20081202?IMSfp=TL081202197004r20373
then one of these on each point one to the gun / or the back of the machine the other into whatever you want to purge
http://cgi.ebay.co.uk/TIG-WELDING-GAS-FLOW-METER-FLOWMETER-0-15-L-M_W0QQitemZ150316290265QQihZ005QQcategoryZ11774QQtcZphotoQQcmdZViewItemQQ_trksidZp1742.m153.l1262
both controled separate to whatever you require
Right, I'm with you now peter, having a mental block then... ;) I'll order them off that site, and I need some bigger tungstens and collets for a second bigger torch I got with the TIG, for welding thicker alloy, I have been struggling with a 1.2 mm tungsten and too thin a filler rod, someone showed me what I was doing wrong the other day, cheers.
