Bender Posted December 15, 2008 Share Posted December 15, 2008 (edited) Hi following that thread http://www.mkivsupra.net/vbb/showthread.php?t=96967 I think I got similar problem. Everything starts 2 weeks ago I come back from work turn off engine and lot's of steam coming up under bonnet so i start looking reason of that and coolant been almost everywhere under manifold and that looks like coming from pipe under that so I buy new one replace and coolant still coming off from somewhere so I take my car to mechanic and he take off water pump and told me the part of water pum need replacing because there is 2 small holes on there (see pics). That always happend when engine catch correct temp and then start blowing off. Any sugestion ? Somebody got similar problem ? I order new pump in Toyota (120 pounds:() PIC'S Edited December 15, 2008 by Bender (see edit history) Quote Link to comment Share on other sites More sharing options...
Luka-P Posted December 15, 2008 Share Posted December 15, 2008 I think you've solved your problem by ordering the new pump. That looks like a core plug of some sort. Quote Link to comment Share on other sites More sharing options...
Bender Posted December 15, 2008 Author Share Posted December 15, 2008 Yeap but... All water pumps "leak" internally. There is sometimes a volume for the water to fill up so that you don't see the leak on the outside - that is until the pump seal wears and the leak gets so large that it fills up the volume. Then there is a small hole to let the water out so that the leak manifests itself. He said about small hole but I got two ! Quote Link to comment Share on other sites More sharing options...
Guest victorvondoom Posted December 16, 2008 Share Posted December 16, 2008 (edited) I had the exact same problem. I removed the core plug and replaced it with another - problem solved.......core plug cost me 50p and a tube of sealent £3. Not had problems with it since. Core plug is 20mm diameter. Edited December 16, 2008 by victorvondoom missed out info (see edit history) Quote Link to comment Share on other sites More sharing options...
Bender Posted December 16, 2008 Author Share Posted December 16, 2008 (edited) I had the exact same problem. I removed the core plug and replaced it with another - problem solved.......core plug cost me 50p and a tube of sealent £3. Not had problems with it since. Core plug is 20mm diameter. Ok Thanks for info. I order new pump already what a shame Where you buy core plug ? Edited December 16, 2008 by Bender (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest victorvondoom Posted December 17, 2008 Share Posted December 17, 2008 Got core plug from local motor factors. Try the old shops as opposed to the likes of Halfords. Not many places stock them nowadays. Failing that, Ebay. Quote Link to comment Share on other sites More sharing options...
Bender Posted December 18, 2008 Author Share Posted December 18, 2008 Got core plug from local motor factors. Try the old shops as opposed to the likes of Halfords. Not many places stock them nowadays. Failing that, Ebay. Ok THX I try fix old pump. New is already fitted and problem is solved:d Quote Link to comment Share on other sites More sharing options...
