bodilx6 Posted December 15, 2008 Share Posted December 15, 2008 As seen in the first pic (right side) with the location pointed out in the next. Last pic is from the left side, and they are clearly not equally placed. The yellowish visible i the first pic is some kind of foam like a seat cushon. Should they be open like this or sealed off? Quote Link to comment Share on other sites More sharing options...
ivan Posted December 15, 2008 Share Posted December 15, 2008 Looks like you've lost some sort of sealing bung from the holes. Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted December 15, 2008 Author Share Posted December 15, 2008 to me it looks like the sealing bung is there, but is now attached to the foamy stuff above the bottom plate. How that happend I dont know... And what is it that is above that? If I'm missing a sealing, does anybody know what the part no is for it? Quote Link to comment Share on other sites More sharing options...
movistar Posted December 15, 2008 Share Posted December 15, 2008 looks like someone has forced it though, and the hole were the grommet sits in is out of shape....try and put the hole back into shape first and refit the grommet which seems to be stuck on the foam under your carpet, i would use a bit of sealer just to be sure when refitting the grommet and finish off with a bit of underseal around that area underneath. Quote Link to comment Share on other sites More sharing options...
