ClaireRZ-S Posted December 14, 2008 Share Posted December 14, 2008 Just fitting the FCD and following the instructions from the this page http://www.mkiv.com/techarticles/fcd/fcd.htm. Just not sure where the white wire goes. Can someone help please. thanks Quote Link to comment Share on other sites More sharing options...
bondango Posted December 14, 2008 Share Posted December 14, 2008 Claire of the top of my head you cut the wire at E9 pin 62 Turbo pressure signal White wire on FCD goes to the cut wire which heads out of car toward the sensor Yellow wire on FCD goes to the cut wire which heads to the ecu connector Quote Link to comment Share on other sites More sharing options...
ClaireRZ-S Posted December 15, 2008 Author Share Posted December 15, 2008 Claire of the top of my head you cut the wire at E9 pin 62 Turbo pressure signal White wire on FCD goes to the cut wire which heads out of car toward the sensor Yellow wire on FCD goes to the cut wire which heads to the ecu connector Cool know what you mean now thanks for the help and thanks to everyone else who replied in this thread Quote Link to comment Share on other sites More sharing options...
