Indicators and Hazards have stopped working
marbleapple
Evening All.
I have had my dash off today trying to fit Hecklers dash conversion bits and some how (in addition to breaking my digital clock) I have managed to stop the indicators from working. The hazard button is also no longer lighting up and when I press it the indicators don’t come on. To add confusion, when I press the 'lock' button on my car alarm the indicators do flash (as they should).
Have I missed something/broken something else?
Evening All.
check if the plug is onto the hazard lts switch.
Its so funny, i have did this exact same thing in 3 of my cars to date. I've taken the dash off, put it all back together forgetting the hazard button.
Least after the first time i knew what it was without going into a panic. Just lots of swearing lol.
Cheers guys.
If I had plugged the wrong one intot he hazard would that make the indicators not work? I.e. even when I presss the stick down to inducate left there is no green arrow etc
Thats exactly what happens when its not plugged in. Absolutely nothing works :)
Thanks guys. That will make things much easier tomorrow morning.
Hecklers stuff is going to look great and looks even better with Supraloopy's new dash. Hopefully I'll be able to post some pics up tomorrow with everything working etc.
Lots of pics required kind sir :)
As above. However, mine failed and the only way to repair was to run another positive wire to the switch. Fuses all OK. I've heard someone else that had the same.
I'm betting yours is just a missed connector though - easy done.
Mine needed a new positive to the hazard switch because of this, horn stopped working too.
