Tyres ok, back end seems to slide
Bradb
Originally posted by Bradb
When pullng away, the back end seems to slide very moderately. Not tyres.
Ideas kids, and also cost to repair, sort. ta
When was the last time the alignment was checked?
New tyres do need a few miles on them before they perform their best.
Why are you discounting the tyres?
Anyone know tyre pressures for
265/35/r18's Rears
245/40/18s Fronts
32 to 36 psi depends on preferance. (someone might correct me on this, as im not an 18"er myself)
brad have u increased yr rolling radius with these new wheels & tyres?
Tyre pressures for the rear tend to be 32-38psi depending on what you've got your fronts at to keep a good balance.
I find that fronts need to be a bit higher pressure than rears but that's purely a personal preference to give a good feel through corners.
-Have you checked your wheel nuts are tight?
-Have you drastically decreased weight in your Supra?
-You haven't ran over some thing big or knocked your suspension recently?
All the above could have an effect on the rear grip of your car.
If you've just got new tyres fitted then they will take about 10-20 miles before the 'protective varnish' layer is worn off. When tyres come out of the mould they have a layer of varnish like a wax type that is embedded into about a millimeter of the tread. Only takes a few wheels spins to get rid of it.
