alloys
beagle
i see some members have 8 1/2 on fronts so will 1/2 inch make that much of a different
You've got to consider the offset aswell.
The stock Supra wheel is 8" wide with an offset of 50mm.
The wheels on Ebay have an offset of 35mm, so the wheel will be moving 15mm towards the wheel arch, because the wheel is 1" wider it will move an additional 1/2" towards the wheel arch.
So in total you're moving the wheel 27.7mm closer to the wheel arch.
