will it cause a problem
nickball75
No warning lights for a start...
I'd have to check the wiring diagram, but I'm pretty sure the speed circuit is buffered via the odo, which means the ECU wouldn't get the speed signal... So you might end up with light powersteering and gearbox change up issues (if auto)... but not 100% without checking the diagram.
Plug hazard lights plug at least to get indicators working
:yeahthat:
The indicators don't work unless you plug the hazard switch back in.
Why would you need to drive the car without plugging the dash back in anyway, it's an easy enough job to fit/refit.
