AFR Gauge/Boost Gauge problem
cadman 26
Ok here goes!!
I fitted my new Alpine head unit last weekend and therefore had to remove the dash and all associated wiring connections.
For reasons i won't go into i had to re-assemble the dash in a bit of a hurry and hence, the boost gauge does now not work (stays at 0) and the AFR gauge seems to be working in reverse!!:search:
Before everyone tells me that i have reconnected stuff wrong, i feel i should explain a couple of things.
The cigarette lighter never worked on my car in the first place so when i put the dash back on i didn't reconnect it. I have read on the forum somewhere since, that the boost gauge on some cars use the power wire from the cigarette lighter to power it. Is this true?
Is it also possible to reconnect the AFR Gauge the wrong way round, as when i press down on the loud pedal i get readings of 16.0+ and at idle it sits at 11.0ish.
Everything on my supe was working fine before my cack handed stereo install!!:innocent:
:sos:
