Hey, quick speed question
Samurai446
Hi everyone. Im wondering if anyone knows approximately wat the top speed is on a j-spec tt. Ive got an apexi induction kit and cat back nur-speed exhaust. As far as i know the boost is running standard. I've got a sld on it and i managed to get to 160mph at 5000rpm. (On a rolling road of course :eyebrows: ) Does this sound pretty right or is the sld not working?
Sounds about right, when my car was stock I did a high speed run and got to an indicated 165mph on speedo. I found that it was very difficult to get the car to keep accelarating once I changed into 6th. If you remove cats and up the boost a little I'm sure you'll find you can get a bit more out of it.
Isn't stock J-spec speed limit around 115mph? Which would mean that your SLD is working fine.
I've gone as fast as it is possible to go in a uk spec supra with the stock speed limiter on numerous occaisions. The indicated speed was considerably higher than 155 when I hit the limiter. :p
It also accelerated to that speed very quickly, even when in 6th gear. :cool:
Don't think I should say anymore in this section of the forum. ;)
