Maxing Injectors out
uestlove
hey guys,
Cliff notes:
Stock turbos, dump pipe, metal cat, cat back, trust intercooler
Bought car, boost spiking to 2 bar.
Figured out Jap guys disconnected something from wastegate.
fixed it, but still spiking to 1.7bar
Fitted HKS EVC6 boost controller..did nothing
bought power fc and tuned it
still hitting 1.7 bar and maxing injectors out
so put 2.5 restrictor in exhaust before and after cat, car is a bit laggier but boost gauge is showing 1.4bar..and engine light coming on
borrow hand controller off friend..knock is at 10 but injector cycle at 100%!
After we put restrictor in, didnt retune it, if i get it tuned again will this help? Thinking get some timing pulled out and hopefully tuner can control boost..fucking hell everytime im ready to hit the track a problem arises.
Should i put a 3" restrictor ring? I have read heaps of threads here, alot of info, but can you please comment on my situation thanks.
Cheers
Are you hitting 1.4 bar with the boost controller turned off? (A boost controller can only raise the boost, not lower it below what it's producing without)
If you are then you need a smaller restrictor ring, not larger.
I too am surprised it hasn't blown up.
edit: reading again it sounds like you have 2 restrictor rings fitted, you only need 1! I'm also curious what this thing is that was "disconnected from the wastegate". As the stock turbo's have an internal wastegate I'm guessing you're meaning something else.
Edited by Thorin (see edit history)
hey guys, yeas i still have the cat, but its a hi flow metal cat. Not restrictive at all. Its the mid cat? The one that sits in t he middle of the car.
Thorn not sure what they broke, my mechanic fixed it, something on the actuators maybe??
Also yeah 2 rings one before the cat and after. They are 2.5". Going to drop them down to 2.45"
