Guest speedline Posted December 8, 2008 Share Posted December 8, 2008 will it fit in the supra mkiv engine bay and marry up to the n/a five speed manual box Quote Link to comment Share on other sites More sharing options...
Tom Posted December 8, 2008 Share Posted December 8, 2008 it'll fit in no probs, go with the mk3 supra turbo gearbox, should save some weight up front too Quote Link to comment Share on other sites More sharing options...
supradriver Posted December 8, 2008 Share Posted December 8, 2008 why not have the 2jz gte ???? Quote Link to comment Share on other sites More sharing options...
Tom Posted December 8, 2008 Share Posted December 8, 2008 1JZ is cheaper Quote Link to comment Share on other sites More sharing options...
Tom Posted December 8, 2008 Share Posted December 8, 2008 here's one installed, but not the neatest install by the looks of it! Quote Link to comment Share on other sites More sharing options...
Guest speedline Posted December 8, 2008 Share Posted December 8, 2008 it looks good to me i want to go with the 1jzgte single turbo are these good for the same power as the 2jz turbos , Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted December 8, 2008 Share Posted December 8, 2008 Soooo You want the 1JZ because its cheap, and yet expect it to develop the same power as the more expensive later version? Quote Link to comment Share on other sites More sharing options...
Tom Posted December 8, 2008 Share Posted December 8, 2008 Soooo You want the 1JZ because its cheap, and yet expect it to develop the same power as the more expensive later version? why wouldnt it? both from factory come out with around 300ish bhp, it maybe 500cc down but it's higher reving, I can't see that it would be that far behind with the same turbo on a 2JZ Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted December 8, 2008 Share Posted December 8, 2008 why wouldnt it? both from factory come out with around 300ish bhp, it maybe 500cc down but it's higher reving, I can't see that it would be that far behind with the same turbo on a 2JZ It will because 1 is not as good as 2. Thank you that is all Quote Link to comment Share on other sites More sharing options...
Tom Posted December 8, 2008 Share Posted December 8, 2008 you can get vvti single turbo 1JZ's too, thats what i'd go for if you can find one Quote Link to comment Share on other sites More sharing options...
Tom Posted December 8, 2008 Share Posted December 8, 2008 It will because 1 is not as good as 2. Thank you that is all the 1JZ just has a shorter stroke? it's near on identical apart from that from what I've read. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted December 8, 2008 Share Posted December 8, 2008 Its just the way of the world im afraid. Would you buy 6up? No you wouldnt, but 7up is fine Quote Link to comment Share on other sites More sharing options...
Tom Posted December 8, 2008 Share Posted December 8, 2008 Ask CW what he thinks he's an expert and he much prefers the 1JZ Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted December 8, 2008 Share Posted December 8, 2008 When i spoke to him on Thursday he commented that he doesnt like 7up, but Fanta is ok. I dont quite think you get what im on about, so ill give up, comedy gold is only funny with an appreciative audience! Quote Link to comment Share on other sites More sharing options...
Tom Posted December 8, 2008 Share Posted December 8, 2008 ok Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted December 8, 2008 Share Posted December 8, 2008 When i spoke to him on Thursday he commented that he doesnt like 7up, but Fanta is ok. I dont quite think you get what im on about, so ill give up, comedy gold is only funny with an appreciative audience! Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 8, 2008 Share Posted December 8, 2008 The single turbo 1JZ engines never feel as strong as the older ones, to me. I do like them though, the shorter stroke of the 2.5 engines make them turbine smooth, the 2JZ feels a bit of a shaker when driven directly after a Soarer or late MKIII Supra. The older straight six BMW engines were the same, the 2.5 was a beauty, the 3.3 a bit rough arsed. Quote Link to comment Share on other sites More sharing options...
Guest speedline Posted December 8, 2008 Share Posted December 8, 2008 yep im looking fot that vvti 1jzgte not easy to get but i can wait i also like the high rev plus i will bolt on a bigger turbo and some 800cc injectors that should do me fine i will keep you posted thaks gang lot of help Quote Link to comment Share on other sites More sharing options...
mrdsukautos Posted December 9, 2008 Share Posted December 9, 2008 run over 400 horses on a non built 1jz and expect it to fail .... Quote Link to comment Share on other sites More sharing options...
DaveR Posted December 9, 2008 Share Posted December 9, 2008 When i spoke to him on Thursday he commented that he doesnt like 7up, but Fanta is ok. I dont quite think you get what im on about, so ill give up, comedy gold is only funny with an appreciative audience! If it helps, I chuckled... Quote Link to comment Share on other sites More sharing options...
PhilMorrison Posted December 9, 2008 Share Posted December 9, 2008 run over 400 horses on a non built 1jz and expect it to fail .... Not even close. Personal experience of 560bhp on 1JZ with the only mods being 256 cams, having run 10k miles at this power, after 60k miles standard power. This engine is in one of our competition car, and is run off the limiter at every given opportunity. The 1JZ engine is one of the strongest engines out there . Quote Link to comment Share on other sites More sharing options...
Guest speedline Posted December 9, 2008 Share Posted December 9, 2008 im looking for a low mileage lump, with them being on the old side thats will be a challenge,anyway i was going for the vvti version but it seems that the standerd con rod on the vvti are thinner, than non 1jzgte vvti, also 2jz tt lump is a bit to much cash and the 1jz t lump has a very good bhp and rev high and will be just as fast im only looking for 400bhp can the stander engine take that ? Quote Link to comment Share on other sites More sharing options...
Tom Posted December 9, 2008 Share Posted December 9, 2008 yes no probs providing its been regularly serviced and looked after, try to find one out of a soarer and at least get a compression test done Quote Link to comment Share on other sites More sharing options...
garethr Posted December 9, 2008 Share Posted December 9, 2008 ... it seems that the standard con rods on the VVTi are thinner than the non-VVTi 1JZ-GTE......Not true. The part number is the same from 1991 to 2000. You're thinking of the GE engines. Quote Link to comment Share on other sites More sharing options...
Guest dangerousandy Posted December 10, 2008 Share Posted December 10, 2008 When i spoke to him on Thursday he commented that he doesnt like 7up, but Fanta is ok. I dont quite think you get what im on about, so ill give up, comedy gold is only funny with an appreciative audience! Rob, you know that I think your the best ....... what ever happed to Mountain Dew, and tab Clear? Did they go the same way as the 1JZ-GTE???? Quote Link to comment Share on other sites More sharing options...
