Tickover too high after ECU reset
Jake
I disconnected my battery of my '98 VVTi Tiptronic while wiring in a Thor FCD (VFCC) and tidying up the existing SLD wiring but when I first started the car after putting it all back together it was idling at 1,600 RPM.
I took the car out for a 5 mile drive but when I got back home the idle was still at 1600 RPM. I lifted the bonnet and was checking for loose pipe and noticed that the revs where gradually dropping without me doing anything. It's now ticking over at 1000 RPM but doesn't seem to be getting any lower.
Any suggestions?
Thanks
I've always found that resetting the ecu (by pulling the efi fuse) usually causes the revs to go low, ie 700 rpm as if the engine is warm, even if it's cold.
You could possibly try resetting it again by pulling the fuse for 30 secs.
Hope you get it sorted. :thumbs:
Resetting it again is worth a try. Generally an ECU reset means the car runs at a too low idle than too high though, and it has a slightly hard time catching a revup and release until you've done it three or four times.
An air leak past the throttle body is THE way of getting a too-high idle, check all the hoses that come off the manifold - brake booster, charcoal canister, MAP sensor, FPR, PAS bypass valve, and cam breather. in fact you could unplug them and see if the idle goes even higher - if not, you may have found your leak :)
-Ian
  • 2 months later...
I recall reading somewhere on this site that after an ECU reset the ECU will adjust revs while relearning the MAP/timing and the such.
it does, but sometimes it get's it's knickers in a twist...as Jake found out. ;)
