She's alive...
scooby_doo_do
Attempted to start up my Ultima spyder today, as it's been sitting in the garage a while now as the weather's been crap.
First attempt, car starts and then stops shortly after.
Second attempt, car start no problem but stalls when you let off the accelerator,
Third attempt, car starts, leave the revs for about 30 seconds just over 1k, and then car seems to tick over nicely.
Obviously i checked all the fluids first and all seemed fine. Had a little bit of smoke the first time it started but this cleared pretty much instantly - prob just crap in the exhausts.
Here's a vid of it idling - think it sounds ok? or in need of a slight tune?
http://www.tripkings.co.uk/ultima.avi
i'll get another one in the daylight tommorrow when it's nicer and i've cleaned it, and fitted the seats. then all i'm waiting for is the steering wheel adaptor and i can take it out for a drive again :-)
On a seperate note, i'd like to charge the battery to give it a little more juice. I've noticed its a sealed tall thin type of battery - does this make a difference to the charger i use, or can i just use the normal halfords charger and leave it in battery type "sealed" ?
Many thanks
Craig.
No idea what engine is fitted but that sounds like it's running a bit rich. Was it properly warmed up by then and presuming it's got a carb, does it have an choke (either auto or manual) fitted? High lift cam?
Really nice car, love it. As Jamie mentioned it'd be great to see that at some events in '09 :)
it has a chevy small block with holley 4 port carbs. Don't think it has a choke at all - car had only been running for about 5-10 minutes when i shot that vid.
Compared to the cerbera this is amazing. The handling is outragous and so is the tourque. With the cerb occasionaly it would catch you out as the back would spin on roundabouts etc with too much right foot, but this just sticks.
Only thing i miss is the roof in this weather :-) but the heater's good, and i've driven it in the rain once (as long as you go over 20mph you dont get wet.
Definatly taking it to some meets next year :-)
