Guest vchukwuma Posted March 20, 2005 Share Posted March 20, 2005 Can anyone tell me how you set the time on a Jap spec Supra??? There are 3 holes to set the time but have tried putting a pin into them but nothing happens. Have taken the dashboard apart and have accessed the clcok but still cannot set clock. Any ideas? Link to comment Share on other sites More sharing options...
paulfurn Posted March 20, 2005 Share Posted March 20, 2005 Havent got a digi clock in mine... BUT.. if you dont have any joy at all with this, then disconnect the clock until 12am, then plug it back in . Hopefully the clock will default to a 12am start time (like most cars digi clocks do once the battery is pulled) and hopefully will have the right time. Its hardly a solution but at least it will tell the right time until you get it sorted properly Link to comment Share on other sites More sharing options...
Matt Harwood Posted March 20, 2005 Share Posted March 20, 2005 With ignition on, so the the clock is illuminated.... Push the H button to adjust the Hours. Push the M button to adjust the Minutes Push the 00 button to reset the minutes to 00 Link to comment Share on other sites More sharing options...
Guest vchukwuma Posted March 20, 2005 Share Posted March 20, 2005 The problem is that there are no buttons... only holes for say something like a pin to go into but will see if I can find something that changes the digits. Link to comment Share on other sites More sharing options...
Matt Harwood Posted March 20, 2005 Share Posted March 20, 2005 Have you got a photo of it? - It sounds broken... Link to comment Share on other sites More sharing options...
