supraspeed Posted December 5, 2008 Share Posted December 5, 2008 anyone used these? any good? http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&Item=390012477660&Category=122154&_trksid=p3907.m29&_trkparms=algo%3DLVI%26its%3DI%26otn%3D2 or http://cgi.ebay.co.uk/25mm-wheel-spacers-skyline-200sx-EVO-RX7-GTO-SUPRA-bolt_W0QQitemZ230298643853QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item230298643853&_trksid=p3286.c0.m14&_trkparms=72%3A1301%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318 Quote Link to comment Share on other sites More sharing options...
Alex Posted December 5, 2008 Share Posted December 5, 2008 Spacers are a bad idea period. They screw up the hubs and you have to replace them, which will cost a similar amount of money to getting wheels that fit properly in the first place! Quote Link to comment Share on other sites More sharing options...
tony tt Posted December 5, 2008 Share Posted December 5, 2008 (edited) They screw up the hubs and you have to replace them, which will cost a similar amount of money to getting wheels that fit properly in the first place! Edited December 5, 2008 by Alex Quote fixed (see edit history) Quote Link to comment Share on other sites More sharing options...
supraspeed Posted December 5, 2008 Author Share Posted December 5, 2008 my wheels fit all but one which rubbed on my caliper so have to get some really as its taken off the caliper paint already...strange its just one wheel. any other ways of doing it? Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted December 5, 2008 Share Posted December 5, 2008 Spacers are a bad idea period. They screw up the hubs and you have to replace them, which will cost a similar amount of money to getting wheels that fit properly in the first place! Im going to go against this. I( dont disagree they will screw your handling) however screw your hubs and bearings im beginning to disagree with. I have to run I think its 30mm spacers on back (must measure them actually) The car has been used close to 3 years as a daily driver and not one problem at all and I do check them because of what i have read on here. Although I agree on a standard supra you should probably make the effort to get good fitting wheels. Mine were going to cost around £2500 and thats when the Yen was at 190!! Quote Link to comment Share on other sites More sharing options...
Alex Posted December 5, 2008 Share Posted December 5, 2008 WSB you probably mince about in that one though and never stress it Wheels rubbing the calipers means that the wheels don't fit...simple really. But if you must use spacers keep them to 5mm Quote Link to comment Share on other sites More sharing options...
Scoboblio Posted December 5, 2008 Share Posted December 5, 2008 I had 3 (or 5?) mm spacers on the front of mine to fit my wheels over UK brakes, hated them with a passion. Had to put longer studs and ugly wheel nuts on to compensate and got a wobble through the steering wheel too - basically it destroyed my confidence in the handling. Given the same situation again, I'd buy wheels that fit 100% right, even if it meant waiting a lot longer for them. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted December 5, 2008 Share Posted December 5, 2008 I had 3 (or 5?) mm spacers on the front of mine to fit my wheels over UK brakes, hated them with a passion. Had to put longer studs and ugly wheel nuts on to compensate and got a wobble through the steering wheel too - basically it destroyed my confidence in the handling. Given the same situation again, I'd buy wheels that fit 100% right, even if it meant waiting a lot longer for them. Sensible man speaks truth Quote Link to comment Share on other sites More sharing options...
sparkystav Posted December 5, 2008 Share Posted December 5, 2008 Just my two pence, if you do buy them, buy the ones with longer studs. I had a set of the other type, and the tool to tighten/remove them was made of chocolate and just bent when i wanted to remove them. Had to grind them off in the end! Quote Link to comment Share on other sites More sharing options...
mr lover Posted December 5, 2008 Share Posted December 5, 2008 grind a bit off the caliper Quote Link to comment Share on other sites More sharing options...
garethr Posted December 6, 2008 Share Posted December 6, 2008 (edited) ...if you must use spacers keep them to 5mmI'd disagree with that. 5mm spacers are not hubcentric, and I wouldn't be confident that the chamfer would let the wheel sit on the spigot. I had 3 (or 5?) mm spacers on the front of mine to fit my wheels over UK brakes, hated them with a passion. Had to put longer studs and ugly wheel nuts on to compensate and got a wobble through the steering wheel too - basically it destroyed my confidence in the handling.See what I mean? Grind a bit off the caliper.Eeek! Edited December 6, 2008 by garethr (see edit history) Quote Link to comment Share on other sites More sharing options...
