House Alarms - Wired or Wireless
Wez
Hey All,
Any security specialists on here?
Previously I have always had wired house alarms fitted but recently a wireless unit was recommended. Apparently the sensors, bell etc have a 3 year battery life and the main unit is mains powered.
Are these any good, how secure are they and what wireless technology do they use?
:cool:
Hi Wez,
funnily enough, I've just had a couple of quotes for a new house alarm.
both companies said wireless PIR's are reliable now, but not really worth the difference in price.
one quote was £500 +vat......the other nearly £800 + vat :(
The only other 'gadget' I was considering was a module that links to the phone line that can text or phone up to 8 different numbers in sequence to warn you when the alartm has been set off.
john
I'm no expert, but fr it would be down to how prone the wireless ones were to false alarming (or not triggering when there was an alarm). Wireless technology has come on a very long way since the first wireless alarms came out (ten years ago??). My mate had one of those and it was nothing but trouble. My wired alarm (installed at the same time) hasn't been much of a bother after the initial "tuning" phase.
Part of my CCTV system is wireless, and that's very robust, but because of the way I've installed it the wireless signals only have to travel a few inches through thin air :) I have heard of people with the same system having issues with interference from WiFi, thick walls, etc.
The guys who installed my wired system were amazing when it came to hiding the wires - mind you, I did already have most of the floorboards up in the affected rooms. It took me about a month to do the wired part of my CCTV.
Personally I'd go for wired but that's ainly because I like a "one size fits all" kind of solution. The idea of having to change lots of different batteries all over the house would annoy me.
This is correct - they're pretty plug'n'play. However my experience is that there are two levels of manuals for many alarm systems: one for end-users and one for installers. Some suppliers won't give end-users access to the installation manuals (for obvious reasons).
My alarm was installed professionally, but sicne it is not a pre-requisite of my H&C insurance I maintain it myself. I recently found the complete installation manual on the interweb (which was a bit scary). Wiring it all together is the easy bit. Going through the millions of setup options using only a 1-9 keypad is a nightmare! :)
This is what i do wez, if you can get wires around the place it is the better more reliable option, i only use wireless if its impossible to cable,ie detached garage or folks have gone ballistic with the laminate flooring, you can also get a standalone autodialler to attach to any wired system, i can send some details over of equipment i use if you need it.
