ballsdeep Posted December 2, 2008 Share Posted December 2, 2008 (edited) basically when i turn right i get a strange humming noise coming from the passenger wheel.... but there is no play in the wheel so im guessing its not bearings??? does anyone have any idea what this could be... it only happens turning right mainly hard cornering.... Edited December 14, 2008 by ballsdeep (see edit history) Quote Link to comment Share on other sites More sharing options...
dani_r Posted December 2, 2008 Share Posted December 2, 2008 When that happened to me I had a weird scraping noise when I turned right, it turned out to be one of the clips that holds the brake pad in place against the disc had moved or bent and was touching the disc. I just got a small grinder on the bit of metal and took a small bit off the end, it now clears the disc with no noise! Not sure if this is what's up with yours but if you pull your wheel off, remove the calliper and pads and just check the clearances of all the clips to see if one might be touching. Quote Link to comment Share on other sites More sharing options...
carl0s Posted December 2, 2008 Share Posted December 2, 2008 basically when i turn right i get a strange humming noise coming from the passenger wheel.... but there is no play in the wheel so im guessing its not bearings??? does anyone have any idea what this could be... it only happens turning right mainly hard cornering.... Could be knackered ball joint. When the balljoint went on my old blue car, it squealed horribly. I thought it was power steering problems but turned out to be totally knackered balljoint. When the car was in the air, mechanic got a crowbar under the wheel and it lifted about an inch! Quote Link to comment Share on other sites More sharing options...
ballsdeep Posted December 13, 2008 Author Share Posted December 13, 2008 Could be knackered ball joint. When the balljoint went on my old blue car, it squealed horribly. I thought it was power steering problems but turned out to be totally knackered balljoint. When the car was in the air, mechanic got a crowbar under the wheel and it lifted about an inch! cheers carl, had my mechanic look at it and what a suprise the noise vanishes, it doesnt seem to be the ball joint or wishbone, what he found was the engine mount had slightly moved [sHOCK][/sHOCK] and the camber needed adjusting on the passenger side, i got abit worried but he told me not to worry!! other than that all he could say was it might be the steering rack.. since it mainly does it when its cold!! next task finding how to adjust camber and more bloody research on the stering rack!!!!! [ANGRY][/ANGRY] Quote Link to comment Share on other sites More sharing options...
