Poor grip at the front affecting backend?
hadyn
Quick question, as I'm not the slightest bit inclined towards basic physics :)
If you're front tyres dont grip as much as the tyres you have on the back of a high powered RWD car such as a Supra, would these theoretically cause the backend to step out - e.g. no grip at the front, but plenty of grip at the back??....
Possibly? If the front end was to go off-course then I suppose the backend wouldn't go where you wanted it to either due to weight of the car being moved?? (Say you go round a corner and the front slips, the the back end would push it further and then come round itself) Is that right???
If the car doesn't have 'sufficient' grip all all four corners that would cause it to be unbalanced - and then something has to give. Being as the power is all at the back, that would be why it steps out.
Just a guess, like.
Does the front wash away at low speeds?
Bad tyres / no grip at the front, as Pot says, can only cause understeer. It is possible to correct it with a sharp application of power to bring the rear round, but is inadvisable if you're not so good at the whole drifting thing.
If you go to a caterham drift day, the opposite is true. Soft track tyres up front, cheapo-nasty highly over inflated tyres at the rear.
Many modern cars have a little understeer in the setup because the opposite is far more dangerous/unpredictable.
