Guest Sanchi Posted November 30, 2008 Share Posted November 30, 2008 Hi guys, Ive got a question. How can you mate the supra gearbox to a 3sgte engine. Im from the mr2 imoc forum and Im hoping to switch to get a supra soon and wanted to put my 3sgte engine in the supra. I just wanted to know if anyone knew how they mated the supra box to the 3sgte engine. I was going to sell up and get a tt supra but Ive got a forged 3sgte engine which would go to waste and I like to do things differently So I have decided to strip the mr2 and put the 3sgte engine in the supra should be fun just need to figure out how the gearbox is connected. Thanks Regards, Sanchi Link to comment Share on other sites More sharing options...
CarlT67 Posted November 30, 2008 Share Posted November 30, 2008 I'd guess its just a specific/custom bell housing made to match the two together.. Link to comment Share on other sites More sharing options...
Guest Sanchi Posted November 30, 2008 Share Posted November 30, 2008 I was looking around for alternatives and on the lexus altezza 3sge engine there is a 6 speed manual gearbox do you think that may work or would the ratios be tooo out.. Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted November 30, 2008 Share Posted November 30, 2008 as far as i'm aware the 6 speed in the IS is the same as the 6 speed in the s15 silvia and is not considered very strong at all. Link to comment Share on other sites More sharing options...
Guest Sanchi Posted November 30, 2008 Share Posted November 30, 2008 (edited) Right.. I see... So who would I be able to contact on here (as Im new to the supra world) regarding a possible custom bell housing to fit a 3sgte engine. Also is the 6 speed n/a the same as the 6 speed tt? are they both getrag boxes? Edited November 30, 2008 by Sanchi (see edit history) Link to comment Share on other sites More sharing options...
Konrad Posted November 30, 2008 Share Posted November 30, 2008 Also is the 6 speed n/a the same as the 6 speed tt? are they both getrag boxes? Boxes are the same (v160 or v161 in newer models), clutch cover is different in NA's, but both (NA's and TT's) clutches do fit to gearboxes without any modifications Link to comment Share on other sites More sharing options...
bondango Posted November 30, 2008 Share Posted November 30, 2008 depends on the power your 3sgte is putting out, you may get way with a w58 5 speed, or even the r154 5 speed. There are w58 to 3s adapters around as they are common in kit cars, also the Ford t56 (?) which is also mated to the 3s in kit cars...The JTTC supras ran hollinger or OS Giken boxes IIRC. Some info on whats needed for RWD configuration http://www.geocities.com/motorcity/7177/3sgtransplant.html There are lots of cars running 3sgte's in RWD with different combo's including the box from a v8 rover..check out http://www.toymods.net Link to comment Share on other sites More sharing options...
Ryan.G Posted November 30, 2008 Share Posted November 30, 2008 Hi Sanj Ryan Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted November 30, 2008 Share Posted November 30, 2008 the gt500 supra's ran hewland transmissions. The hks widebody gt300 ran a stock 6 speed but who knows what fab work they did to make it fit. I think your best bet would be a w58 with its bellhousing and then just make your own adaptor plate to match the bolt pattern on the back of a JZ. Link to comment Share on other sites More sharing options...
edge Posted November 30, 2008 Share Posted November 30, 2008 There was a lexus in japanese performance mag a few issues back that had a 600bhp 3s-gte in and that had a manual box. Not sure what one though. Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 30, 2008 Share Posted November 30, 2008 I can sort out a custom bellhousing, but the stock Getrag doesn't use a removable bell, so a different box may be more readily adaptable. Borg Warner T5 with dog box internals maybe? Whatever you do will be expensive, probably very expensive. A full weight MKIV with a 3SGTE in it will be horrible, look at the weights of the race cars, VAST difference. Unless you get the package under 1200 Kgs and even then want a revvy race track machine, I think it's a backward step. Link to comment Share on other sites More sharing options...
JDModified Posted November 30, 2008 Share Posted November 30, 2008 Hi Sanj, thought you would try to make best use of that engine I built for you Im putting a 2jz in my mr2 im sure I can help you put that 3s in the supra, give me a call to catch up. James Link to comment Share on other sites More sharing options...
Guest Sanchi Posted November 30, 2008 Share Posted November 30, 2008 (edited) Hi Sanj Ryan Hey Ryan, Im already thinking of a new project mate! Lets see how this goes! Hi Sanj, thought you would try to make best use of that engine I built for you Im putting a 2jz in my mr2 im sure I can help you put that 3s in the supra, give me a call to catch up. James Hey James! Im going to give you a call to see what we can do mate! Hopefully I'll be able to pull this off! Edited November 30, 2008 by Sanchi (see edit history) Link to comment Share on other sites More sharing options...
Guest Sanchi Posted November 30, 2008 Share Posted November 30, 2008 Thanks for the responses guys I think the w58 adaptor sounds good for the meantime until I can afford a box that is better. The car will go on a crash diet and will try to make it as light as possible. How can I tell the difference between the w58 boxes and the r154 boxes as I was thinking of buying a 5 speed n/a and using the box from that. Link to comment Share on other sites More sharing options...
TLicense Posted December 1, 2008 Share Posted December 1, 2008 I can sort out a custom bellhousing, but the stock Getrag doesn't use a removable bell, so a different box may be more readily adaptable. Borg Warner T5 with dog box internals maybe? Whatever you do will be expensive, probably very expensive. A full weight MKIV with a 3SGTE in it will be horrible, look at the weights of the race cars, VAST difference. Unless you get the package under 1200 Kgs and even then want a revvy race track machine, I think it's a backward step. I'm not sure if I agree to be honest Chris. I've been thinking about the weight distribution over the weekend with regards to a couple of projects people have got on the go. Ideally you want approximately 40-ish% front weight balance, which I just don't think is achievable with the 2JZ. It just weigh's too much. As people junk stuff out to drive down the total weight of the car (a fair percentage from the rear) if anything I should think it will exasperate the problem. I guess it would be possible to strip the car until it's a total featherweight and then start to add tungsten ballast to the bottom of the car to get the distribution back, but then you'll be driving the overall weight back up.... I think fitting a 3SGTE as far rearwards as possible would be a good step. The only problem I really see is that you're going to want about 500bhp and a nice healthy torque curve to go with it, but I don't know if the 3SGTE is going to reliably produce that, and lets be honest, I doubt many people on here are going to have the sort of cash to be rebuilding an engine two or three times a season. Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted December 1, 2008 Share Posted December 1, 2008 in my opinion a v8 sorts this problem, 1uz must be lighter than a cast iron 2J and is only 4 cylinders long, it can sitting further back and lower than a 2j and the torque from it would kill a 3S so for me a 3s would be a bad option, ok for a racecar thats always having its tits revved off but for a road car its a bit pointless, the power delivery of a 2j is bad enough when its wet but a 3sgte running huge boost at high rpm and absolutely no torque below 2-2.5k is going to be more of a hinderence, unless the OP is planning on having it as a track car or something. Link to comment Share on other sites More sharing options...
TLicense Posted December 1, 2008 Share Posted December 1, 2008 Ah I thought it was for a track car. Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 1, 2008 Share Posted December 1, 2008 Ah, I thought it was to be a road car.... Link to comment Share on other sites More sharing options...
Guest Sanchi Posted December 1, 2008 Share Posted December 1, 2008 hey guys its going to be for a road car/weekend track car. Its still just a thought at the moment still looking the advantages and disadvantages I would like to really like to do it but need more research! Link to comment Share on other sites More sharing options...
garethr Posted December 1, 2008 Share Posted December 1, 2008 How can I tell the difference between the w58 boxes and the r154 boxes as I was thinking of buying a 5 speed n/a and using the box from that.5-speed N/A is the W58. Link to comment Share on other sites More sharing options...
Guest Sanchi Posted December 2, 2008 Share Posted December 2, 2008 aaahhh... the w58 is the n/a box... would the ratios be ok for the 3sgte and would it be strong enough? or is it best to go with something like the r154? Link to comment Share on other sites More sharing options...
Guest Sanchi Posted December 4, 2008 Share Posted December 4, 2008 also just wanted to know when using the supra box can I use my 3sgte clutch and flywheel or do I have to use the 3sgte flywheel but supra clutch? or does it not matter what clutch I use? Link to comment Share on other sites More sharing options...
botachi Posted December 5, 2008 Share Posted December 5, 2008 Hi Sanchi! Email Trial Tuning in Japan, they have an English speaking sales rep (American or English I think) who is very helpful. Trial has a 3SGTE engined Supra with I believe the Getrag V160/V161 gearbox in it. He might be able to point you out to the right direction as to how Trial Tuning did theirs. HTH! Link to comment Share on other sites More sharing options...
Guest vvtiguy Posted December 31, 2008 Share Posted December 31, 2008 Piece of cake, you want a 2S bellhousing. You can buy these from Toyota Directly (assuming they still have one lingering around the belgian warehouse somewhere). Using the 2S bellhousing you can mate a W58 straight onto a 3S. You will then need Altezza RS200 Engine mounts which you can also buy straight from Toyota. Best place for this kinda conversion is Toymods as the aussies love doing RWD 3SGTE conversions Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 31, 2008 Share Posted December 31, 2008 I am impressed Mr. vvtiguy I subscribed to that forum a bit ago, i must stick my head in and discuss my turbo 4A-GE conversion there, I suspect there are a few wild conversions in Oz Link to comment Share on other sites More sharing options...
