DIY refurb of 3 Piece Split Rims
jevansio
  • Replies 104
You could have done the brushed look easily yourself, just use a scotch brite pad :D
All I have been doing last month and this month is Black centers and silver or polished outer lips, here's some Lambo rims, I done for inspiration ;)
http://www.speedwells.co.uk/USERIMAGES/241220081034sml.jpg
Your work is 2nd to none Ibrar, when I get my Racing Harts done I'll be sending them down to ya :)
No Dunk, I'm just leaving them like that. They've got a brushed aliminium finish which I think is quite sporty, the mirror finish is too bling for me when I'll be using these as my track/fast road wheels.
I'm pleased you posted that pic as that is the way I want mine doing, black inners. I was going to mask off the area where the studs go & spray that black too so the studs show up. Yours look stunning there :thumbs:
PS did you not go all black with yours? Was that pic an inbetween shot?
Yep mine are all black now, inners, outers and center piece with new wheel bolts.
I was going the polished route but had a small change of plan :D
  • 3 weeks later...
Well considering this was supposed to be a DIY refurb I've done pretty poor. I tried cleaning up 1 centre & got p1ssed off so sent them to the local wheel refurb place to get done.
I chose silver as I'm most likely not keeping these now & I thought silver centres would open my target audience up over black centres.
The lips are just layed over the centres at the mo so aren't perfectly flat and look a little crooked.
Just need to bolt them up now & seal them :).
A couple just to compare how they started:
:thumbs:
Cheers Dunk, I didn't know that, cheers for the tip :D
No problem and good luck fitting them back together, easy way we found at Ibrars was to stack 4 tyres on there side and stand the wheel vertically in the tyres so you can reach round each side easily to do the bolts up and not damage the wheel.
What torque are you pulling the bolts up to ?
I have no idea, I've read it depends on how many bolts there are, what do you recommend????
  • 1 month later...
Since I wasn't getting a sniff at the rims when they were £800 I thought I'm not letting them go for peanuts so I decided they would become my "driving" wheels. They're lighter than my Racing Harts, 18" as opposed to 19" so should handle better & I have more choice in tyre sizes from the R888 range.
I've been busy this morning bolting the 1st one back together. Still got the valve to put in & apply the sealant.
The bolts took me ages, I had to free the threads so the nuts went on finger tight, then polish each of the heads that are visible, took me around 2 hours to do 1 wheels worth :)
I know they're not perfect, but they'll do for when I go on spirited runs over the moors on track days :)
And again for comparison:
Edited by jevansio (see edit history)
