Guest ravi Posted November 30, 2008 Share Posted November 30, 2008 i have a 93 japan spec n/a supra what would happen if i upgrade the fuel pump and put on 550 injectors with an aftermarket extractor? thks ravi Quote Link to comment Share on other sites More sharing options...
michael Posted November 30, 2008 Share Posted November 30, 2008 You'd waste your money, use more fuel and gain no power. HTH. Quote Link to comment Share on other sites More sharing options...
Nic Posted November 30, 2008 Share Posted November 30, 2008 i have a 93 japan spec n/a supra what would happen if i upgrade the fuel pump and put on 550 injectors with an aftermarket extractor? thks ravi As said it would just run very rich and you would lose power. Adding more fuel doesn't gain power. Quote Link to comment Share on other sites More sharing options...
Kranz Posted November 30, 2008 Share Posted November 30, 2008 As said it would just run very rich and you would lose power. Adding more fuel doesn't gain power. Unless its a diesel Quote Link to comment Share on other sites More sharing options...
michael Posted November 30, 2008 Share Posted November 30, 2008 Or a space ship. Quote Link to comment Share on other sites More sharing options...
mikeyb10supra Posted November 30, 2008 Share Posted November 30, 2008 Dear 'o' Dear these technical threads are getting way beyond my experience levels nowadays. Im glad you and nic were there to help out michael Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted November 30, 2008 Share Posted November 30, 2008 i have a 93 japan spec n/a supra what would happen if i upgrade the fuel pump and put on 550 injectors with an aftermarket extractor? thks ravi Extractor? you must have been trawling american webistes:p I think you mean aftermarket manifold, extractors describes the primaries in a individual tubular style manifold and so you would need more than one 'extractor'. Even if you did stick an aftermarket manifold on it you wouldn't need the injectors as you'd be lucky to see another 10-15hp and if you stuck 550's on it you would probably have trouble even starting it after a while. Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted November 30, 2008 Share Posted November 30, 2008 Where's IanC when you want someone to brush something like this out of Technical?! Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 30, 2008 Share Posted November 30, 2008 i have a 93 japan spec n/a supra what would happen if i upgrade the fuel pump and put on 550 injectors with an aftermarket extractor? thks ravi If your car runs at all with 40% more fuel going into the engine, you will loose power, and you will promptly kill your engine due to the amount of fuel going past the rings, if you're going to think about tuning an engine, please do some basic reading, so you at least can ask sensible questions. Quote Link to comment Share on other sites More sharing options...
Guest ravi Posted November 30, 2008 Share Posted November 30, 2008 thks all Quote Link to comment Share on other sites More sharing options...
