jevansio Posted October 24, 2009 Share Posted October 24, 2009 I cant recall a single failure and im on the most evenings like yourself:D It's not like they'd hide it either, if they had them we'd know about it, Link to comment Share on other sites More sharing options...
Paul Whiffin Posted October 24, 2009 Share Posted October 24, 2009 Could be worth checking your manifold Jamie, make sure its not melting and allowing bits of metal through your turbo, its happened to me before. Link to comment Share on other sites More sharing options...
JamieP Posted October 24, 2009 Share Posted October 24, 2009 Could be worth checking your manifold Jamie, make sure its not melting and allowing bits of metal through your turbo, its happened to me before. I will get Lee to check it. Link to comment Share on other sites More sharing options...
Geo Posted October 24, 2009 Share Posted October 24, 2009 Jamie how long have you run that turbo for?? i know you give them a good beasting, just worried now mine will go like that after a good thrashing. Link to comment Share on other sites More sharing options...
dandan Posted October 24, 2009 Share Posted October 24, 2009 (edited) Looking through the back it looked great but upon opening i found this AGAIN!! What the hell is up with these exhaust housings. You can see that the inside of the casting is just falling to pieces and damaging the turbo! Going to see if owens can salvage something between both the turbos and make one good one. While they are doing that im just going to bite the bullet and get a borg warner turbo now. Thats 4 precision turbo i have had do this to me and seen over 8 do this now! Oh dear mate - that looks like sh!t. The turbine wheel does look badly distorted at the base as well as a tiny bit "chipped" and "eaten away". This is how mine looked for comparison.... If you want me to take a look at the housing I may be able to diagnose whether the housingitself is definitely failing or if it is tiny particle damage from elsewhere attacking the housing. I have access to some excellent imaging and magnification kit which may yield a lot more than a visual or "mangnifying glass" inspection. Edited October 2, 2013 by dandan (see edit history) Link to comment Share on other sites More sharing options...
jevansio Posted October 24, 2009 Share Posted October 24, 2009 You can see that the inside of the casting is just falling to pieces and damaging the turbo Ryan, I don't think you posted the pic up to which that text is referring? Link to comment Share on other sites More sharing options...
AlexJames Posted October 26, 2009 Share Posted October 26, 2009 Any luck on those Hi res photos of this one? Link to comment Share on other sites More sharing options...
csa Posted October 26, 2009 Share Posted October 26, 2009 interesting info on the Precision units here. I run a T67 as well. the turbo is a non dbb, about 4 years old and has about 8k miles on it now. The last time I inspected it, it was all dandy but since the car has had a remap to 1.6 bar (from 1.3) but EGT's are the same. I will pull it off during the winter and have a look again. Link to comment Share on other sites More sharing options...
dandan Posted October 26, 2009 Share Posted October 26, 2009 What size exhaust housing Christian? Link to comment Share on other sites More sharing options...
csa Posted October 26, 2009 Share Posted October 26, 2009 the infamous .68 Link to comment Share on other sites More sharing options...
JamieP Posted October 26, 2009 Share Posted October 26, 2009 I dont think its anything to do with the housing size, the GT4088 .96 on Christian's car also melted/fell to bits in the same way. Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 26, 2009 Share Posted October 26, 2009 If the turbine housing isn't Ni-Resist or similar high nickel content cast iron just forget it. You need to ask in writing if a given turbo has such a housing. Cheap grey nodular stuff just flakes and particles erode the wheel or worse. The genuine Garrett listings show which turbos have these housings. Link to comment Share on other sites More sharing options...
Steve Posted October 26, 2009 Share Posted October 26, 2009 (edited) I got a reply to my email. 'Foreign object damage'. I have replied Edited October 26, 2009 by Steve (see edit history) Link to comment Share on other sites More sharing options...
Steve Posted October 26, 2009 Share Posted October 26, 2009 (edited) Well after a few emails, they said a few possible causes. Material from the manifold coming away, a bolt or nut dropped in the manifold or a spark plug. I then sent the picture of Jamie's T67 and then got the old reply of foreign object damage. To which I replied that I find it hard to believe that it was that due to the number of failures occurring. So was advised to go back to Boostlogic and get them to deal with it. I could also have sent h the unit back to them for repair, but after shipping, the repairs and new exhaust housing I figured it would be better start again. Well looking forward now, I will not be using a Precision turbo again so am looking at the Borg Warner units. Edited October 26, 2009 by Steve (see edit history) Link to comment Share on other sites More sharing options...
Steve Posted October 26, 2009 Share Posted October 26, 2009 Oh dear mate - that looks like sh!t. The turbine wheel does look badly distorted at the base as well as a tiny bit "chipped" and "eaten away". This is how mine looked for comparison.... http://i828.photobucket.com/albums/zz202/danc8000/Turbo/CIMG2907a.jpg If you want me to take a look at the housing I may be able to diagnose whether the housingitself is definitely failing or if it is tiny particle damage from elsewhere attacking the housing. I have access to some excellent imaging and magnification kit which may yield a lot more than a visual or "mangnifying glass" inspection. Dan shall I send you my old exhaust housing? Link to comment Share on other sites More sharing options...
Paul Whiffin Posted October 26, 2009 Share Posted October 26, 2009 Well after a few emails, they said a few possible causes. Material from the manifold coming away, a bolt or nut dropped in the manifold or a spark plug. I then sent the picture of Jamie's T67 and then got the old reply of foreign object damage. To which I replied that I find it hard to believe that it was that due to the number of failures occurring. So was advised to go back to Boostlogic and get them to deal with it. I could also have sent h the unit back to them for repair, but after shipping, the repairs and new exhaust housing I figured it would be better start again. Well looking forward now, I will not be using a Precision turbo again so am looking at the Borg Warner units. I've been looking at using the Borg Warner's in my turbo kits for awhile now, from what I've heard they are suppose to be the nuts. I'll be trying one out very soon. I can get them at good prices if you need one mate, let me know which one. Link to comment Share on other sites More sharing options...
Steve Posted October 26, 2009 Share Posted October 26, 2009 I've been looking at using the Borg Warner's in my turbo kits for awhile now, from what I've heard they are suppose to be the nuts. I'll be trying one out very soon. I can get them at good prices if you need one mate, let me know which one. PM on the way Link to comment Share on other sites More sharing options...
Ryan.G Posted October 26, 2009 Author Share Posted October 26, 2009 Ryan, I don't think you posted the pic up to which that text is referring? See post 826 Any luck on those Hi res photos of this one? Yup e-mailing it over now mate Link to comment Share on other sites More sharing options...
Ryan.G Posted October 26, 2009 Author Share Posted October 26, 2009 If the turbine housing isn't Ni-Resist or similar high nickel content cast iron just forget it. You need to ask in writing if a given turbo has such a housing. Cheap grey nodular stuff just flakes and particles erode the wheel or worse. The genuine Garrett listings show which turbos have these housings. I have a genuine garett housing and a precision one spare now. Im going to get somebody to check out the materials and temperature resistance. Got anyone who can do this Chris? Link to comment Share on other sites More sharing options...
Ryan.G Posted October 26, 2009 Author Share Posted October 26, 2009 Do you think this could be due to my high egt's? when cruising on the motorway at 70-80 mine are in the 800's? Nah most commercial cars these days have a cruise Egt of between 700-800c. On a Impreza WRC the exhaust gas temps go over 1000c+ all the time and i have never seen a WRC turbo do this! Ryan Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 26, 2009 Share Posted October 26, 2009 I have a genuine garett housing and a precision one spare now. Im going to get somebody to check out the materials and temperature resistance. Got anyone who can do this Chris? A friend has used these people for drive shaft analysis, but it won't be cheap: http://www.materials.co.uk/ Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 26, 2009 Share Posted October 26, 2009 Bear in mind a proper WRC spec turbo is upwards of 6 grand Sterling.... WRC car technology doesn't come cheap, here is a brief breakdown of a Ford Focus WRC car build cost: http://homepage.virgin.net/shalco.com/focus_wrc_costs.htm Link to comment Share on other sites More sharing options...
Paul Whiffin Posted November 2, 2009 Share Posted November 2, 2009 Have you got the Borg Warner on yet mate? Link to comment Share on other sites More sharing options...
Ryan.G Posted November 3, 2009 Author Share Posted November 3, 2009 Pics of new Borg Warner Turbo Went for the S300sx 91/79 and got it from AET Turbos for a great price. Thanks Andy They are a european supplier for the BW units and carry all repair kits in stock. No messing about sending crap back to Precision! Things that are different then for owners who have Precision or Garrett Units. Firstly the V Band flange has to be modified if running a 3" downpipe as they normally come with 4" v bands. AET did this for me FOC. Next the compressor outlet is 3" instead of the normal 2" 1/2 Lastly the oil feed fitting is 1/4 instead of 1/8npt Here are some pics below of me fitting the unit. Link to comment Share on other sites More sharing options...
Ryan.G Posted November 3, 2009 Author Share Posted November 3, 2009 Have you got the Borg Warner on yet mate? Nearly their chap just waiting for the 76mm to 63mm reducer Ryan Link to comment Share on other sites More sharing options...
