Supra Track Car Project
Ryan.G
  • Replies 1k
Congratulations on a job well done Ryan, its a credit to you and the rest of the team.
I must admit I'm more than a little jealous that yours looks like that and mine looks shite!
Your shoulder straps should cross over before you slot them through the openings in the seats. That way should the worst happen they tend to close tighter around you instead of spreading and allowing you to bend/fly forward.
Best of luck with it Ryan, keep 'er lit!
Epic.
What turbo did you replace the GT35R with? All mapped and set to go?
Went with a Garrett Gt4088 in the end on a 0.81 housing.
Mapping hopefully on thursday if i get time and sorting the geo at the same time.
Just need to sort a driver for towing the car as unfortunely i dont have a towing licence :(
Ryan
I never knew that. Thanks chap :thumbs:
Looks good Ryan, will you be running at Suprapod next weekend now??
Have not forgot I still owe you money will get it paypaled to you ASAP. Just been busy with germany and everything.
The car will be going through some serious abuse the day before hopefully so i cant ensure it will be good to use it on saturday. Doubt i will do the Drag but might have a play on the drift area if their isn't too many other nutters on the area at the same time.
I will be busy working my arse off on saturday as usual anyway
Ryan
Ryan
With the car looking so good I doubt you will do the drift when you see the surface as there are drains and great big dips on the sufface if they use the usual area. Thats the main reason im not having a go.
Would not have thought there is much you can do mapping wise at a drag event??
Tweaking launch controls mainly and supporting some of the big power supras that are their which i map. Mainly be working with Steve sherwood and Gledo
Ryan
