Ryan.G Posted June 2, 2009 Author Share Posted June 2, 2009 it's been so long i can't remember what turbo you're using. I seem to remember gt35r but that looks like something else? gt3582r 0.68 Link to comment Share on other sites More sharing options...
MarkR Posted June 2, 2009 Share Posted June 2, 2009 (edited) Hmmm... I have the same one at home but don't have those holes in the front.... http://www.mkivsupra.net/vbb/showpost.php?p=2115083&postcount=117 AntiLag aren't they? Edited June 2, 2009 by MarkR (see edit history) Link to comment Share on other sites More sharing options...
Ryan.G Posted June 2, 2009 Author Share Posted June 2, 2009 (edited) Hmmm... I have the same one at home but don't have those holes in the front.... http://www.mkivsupra.net/vbb/showpost.php?p=2115083&postcount=117 AntiLag aren't they? Anti-Surge Edited June 2, 2009 by Ryan.G (see edit history) Link to comment Share on other sites More sharing options...
Ryan.G Posted June 2, 2009 Author Share Posted June 2, 2009 Few more pics Link to comment Share on other sites More sharing options...
Ryan.G Posted June 2, 2009 Author Share Posted June 2, 2009 Can anyone help with this http://www.mkivsupra.net/vbb/showthread.php?p=2396749#post2396749 Link to comment Share on other sites More sharing options...
Alex Posted June 2, 2009 Share Posted June 2, 2009 Ryan, is that lower orange hose the oil return? AFAIK it should be as straight and close the vertical as possible to aide gravity, are you limited on this by the manifold or choice? IMO the end going into the pan should be a 45deg joint on a #10 line. It could be the photo but yours current appears to dip below the level of the exit into the pan which isn't optimal. PS I'm not trying to be a picky PITA, loving the project so far Link to comment Share on other sites More sharing options...
Ryan.G Posted June 2, 2009 Author Share Posted June 2, 2009 Ryan, is that lower orange hose the oil return? AFAIK it should be as straight and close the vertical as possible to aide gravity, are you limited on this by the manifold or choice? IMO the end going into the pan should be a 45deg joint on a #10 line. It could be the photo but yours current appears to dip below the level of the exit into the pan which isn't optimal. PS I'm not trying to be a picky PITA, loving the project so far Yes the lower one is the return and from the picture again i can see your point but the engine is on a 30 degree angle on the engine stand which makes it look like it dropping below the oil sump level which as you said is not ideal at all. With DBB turbos having as close to vertical is not requires as much as the normal journey bearings as the pressure out of the return is so small with the DBB restrictors on the feed. Prefer if you point out stuff like this mate. I am bound to miss a few things Link to comment Share on other sites More sharing options...
paul mac Posted June 2, 2009 Share Posted June 2, 2009 whats occuring with the capped brake vacuum Ryan, did i miss you ditching the servo somewhere Link to comment Share on other sites More sharing options...
Kev.O Posted June 2, 2009 Share Posted June 2, 2009 whats occuring with the capped brake vacuum Ryan, did i miss you ditching the servo somewhere Someone's been watching Gavin and Stacey a little too much Link to comment Share on other sites More sharing options...
paul mac Posted June 2, 2009 Share Posted June 2, 2009 Someone's been watching Gavin and Stacey a little too much i think you'll find its to much Scott Mills Link to comment Share on other sites More sharing options...
Ryan.G Posted June 3, 2009 Author Share Posted June 3, 2009 whats occuring with the capped brake vacuum Ryan, did i miss you ditching the servo somewhere Yup servo is long gone. Got a longer throw pedal box to accomodate. Catch up Paul!! Link to comment Share on other sites More sharing options...
MarkR Posted June 3, 2009 Share Posted June 3, 2009 Anti-Surge I'm sure that's what I meant to type Link to comment Share on other sites More sharing options...
b_have Posted June 3, 2009 Share Posted June 3, 2009 Anti-Surge and PRO-Lag if the application isn't prone to surge. I have made an adjustable anti-surge housing for mine which, when adjusted out (looks and sounds like a T51) kills spool by around 150 rpm. I now run it closed, even though the 51 whistle sounded nice Link to comment Share on other sites More sharing options...
paul mac Posted June 3, 2009 Share Posted June 3, 2009 Yup servo is long gone. Got a longer throw pedal box to accomodate. Catch up Paul!! sorry, i'll get my coat Link to comment Share on other sites More sharing options...
Ryan.G Posted June 6, 2009 Author Share Posted June 6, 2009 (edited) Engine is finally ready to go in today... hopefully!, Just pray everything fits around the steering column cover. So last bits done on the engine was finally finish the shimming process. Massive thanks to Tony with this for surface grinding the shims and helping throughout. Cams fitted Time to put all the new seals on covers etc from engine gasket kit and time it up Then new shorter belt which removes the A/C Finally the Loom Wish me luck today and hopefully some fitted pics tonight! Edited June 6, 2009 by Ryan.G (see edit history) Link to comment Share on other sites More sharing options...
T2 MSW Posted June 6, 2009 Share Posted June 6, 2009 Hope it goes well today Ryan I'm on the train to pick mine up now. Another brave soul with no air con Are you also taking the rad and condensor out? How big a job is it? Link to comment Share on other sites More sharing options...
kslb Posted June 6, 2009 Share Posted June 6, 2009 Yep, good luck, really looking forward to seeing this completed. Link to comment Share on other sites More sharing options...
Wez Posted June 6, 2009 Share Posted June 6, 2009 Good luck matey Link to comment Share on other sites More sharing options...
dr_blackman Posted June 6, 2009 Share Posted June 6, 2009 Yeah good luck Link to comment Share on other sites More sharing options...
Kev.O Posted June 6, 2009 Share Posted June 6, 2009 Good luck Ryan Link to comment Share on other sites More sharing options...
Luxluc Posted June 6, 2009 Share Posted June 6, 2009 Good luck Ryan Link to comment Share on other sites More sharing options...
johnd-mkiv Posted June 6, 2009 Share Posted June 6, 2009 good luck Ryan got that treat of a job shimming the cams this week too Link to comment Share on other sites More sharing options...
Ryan.G Posted June 6, 2009 Author Share Posted June 6, 2009 Well after 7 hours of swearing and ranting its finally in Massive!! thanks to Steve for helping to the end. True legend. Here are some pics from the day. Before anyway asks.. Yes the cam cover is going to be Sprayed White!! lol Just need to connect and tidy it all up now. Link to comment Share on other sites More sharing options...
JamieP Posted June 6, 2009 Share Posted June 6, 2009 Looks great, if you need any silicon joiners for conecting up the IC, air filter etc i have shit loads of the stuff in the shed you can look though mate. Link to comment Share on other sites More sharing options...
Homer Posted June 6, 2009 Share Posted June 6, 2009 Coming together nicely mate! Looking forward to the next installment I wanted to ask earlier if you're installing any additional support for the turbo, manifold or wastegate - I.e. to help stop cracks on the runners? Still no concerns about cabin heat issues? There doesn't seem to be much insulation (not a critism, just curious) Link to comment Share on other sites More sharing options...
