StuartW Posted January 26, 2009 Share Posted January 26, 2009 Also got a Varley Lightweight battery thanks to Michelle Lane and also a set of Uk brakes I also run a Varley red top 25 only weighs 5.2Kilos! Demon tweeks do a nice aluminium holder for this cost about £30 and a lovely piece of kit. I have been using these batteries on the race boat for 5 years and they really are far more capable than any Spiralux,wet battery 3 times its weight! Hard to believe but i have proved it. Keep up the amazing work Ryan.. Link to comment Share on other sites More sharing options...
supra Posted January 26, 2009 Share Posted January 26, 2009 It wont be legal with the Cusco cage tube diameter. its not the diameter thats the problem, it will be the "swan" legs up front that will not be approved. he would need to get rid of the swan legs up front to pass it through scroots. EDIT: just checked rules and as we have altered the chassis we would not be allowed to enter anyway. you can still enter with chasis alterations BUT it needs to be pre-approved by the time attack scroots prior to entry. Link to comment Share on other sites More sharing options...
Ryan.G Posted January 26, 2009 Author Share Posted January 26, 2009 its not the diameter thats the problem, it will be the "swan" legs up front that will not be approved. he would need to get rid of the swan legs up front to pass it through scroots. you can still enter with chasis alterations BUT it needs to be pre-approved by the time attack scroots prior to entry. Hey chap Thanks for the advise The Legs will be sorted Ryan Link to comment Share on other sites More sharing options...
Ryan.G Posted January 28, 2009 Author Share Posted January 28, 2009 Steve spent some more time on the car finishing of the layout of the floor tonight. Once he is happy that everything is perfect. Then it will be seam welded. This should stiffen things up abit and weigh alot less.... we hope Just wanted to say again guys that please dont just praise me for any work on this project, most of the design and fabrication is being done by Steve at Autotec2004 who has been doing this stuff for years. He normally just works on specialist cars hence why you might see a special car in the back ground of some of the pics but im starting to twist his arm about working on a few special supras as Autotecs bodywork and fabrication skills are another level to everything i have seen in the past. Ryan Link to comment Share on other sites More sharing options...
Ryan.G Posted January 28, 2009 Author Share Posted January 28, 2009 Also ignore the big rusty bar holding the gearbox at present this will be removed and supported by the floor and the gear tunnel when its all fully welded in place. Link to comment Share on other sites More sharing options...
paul mac Posted January 28, 2009 Share Posted January 28, 2009 Ryan are you skinning all the frame work with aluminium sheet or CF , should make it very smooth underneith Link to comment Share on other sites More sharing options...
Ryan.G Posted January 28, 2009 Author Share Posted January 28, 2009 Ryan are you skinning all the frame work with aluminium sheet or CF , should make it very smooth underneith Will be done with Alu sheet chap Link to comment Share on other sites More sharing options...
Pete Posted January 29, 2009 Share Posted January 29, 2009 (edited) That very much resembles how my Tiger started....but you've got a Supra shell on top! I hope you like riveting. Don't forget to put some sealant between the panels and chassis members when fitting them, just helps keep the moisture out and sitting on the rails. How are you going to protect the metal? (please don't say Hammerite!) Edited January 29, 2009 by Pete (see edit history) Link to comment Share on other sites More sharing options...
Ryan.G Posted January 29, 2009 Author Share Posted January 29, 2009 That very much resembles how my Tiger started....but you've got a Supra shell on top! I hope you like riveting. Don't forget to put some sealant between the panels and chassis members when fitting them, just helps keep the moisture out and sitting on the rails. How are you going to protect the metal? (please don't say Hammerite!) Hi Pete The car is starting to remind me of my F27 kit car also : The chassis members will indeed be sealed between the members and the floor but on some of the panel which we will be making removable it will have some rubber pad seal. The whole interior and exterior will be sprayed afterward but not sure in the material which steve would use to protect the metal. Thats his sector Time will tell though surely Ryan Link to comment Share on other sites More sharing options...
Ryan.G Posted January 30, 2009 Author Share Posted January 30, 2009 Spent abit more time on the cage tonight using a new tube notching tool i got. The pics pretty much explains how it works but it makes life alot easier joining pipes up!!!! After a few tests with the notcher i got to work on making the door bars, rear support, front bar and the front suspension turrets. Here are a few tested fitment pics Also strengthened the Swan legs which is all going to be welded up tomorrow and then gusseted which will then allow it to pass MSA regs we have been told. Ryan Link to comment Share on other sites More sharing options...
Branners Posted January 30, 2009 Share Posted January 30, 2009 just remind me, is that going to be road legal eventually or purely for track? Link to comment Share on other sites More sharing options...
JamieP Posted January 30, 2009 Share Posted January 30, 2009 just remind me, is that going to be road legal eventually or purely for track? Road legal. Link to comment Share on other sites More sharing options...
Ryan.G Posted January 30, 2009 Author Share Posted January 30, 2009 Cage looks impressive, you gonna cut a hole in the roof so i can get in mate? Will need to cut the gear tunnel as well Link to comment Share on other sites More sharing options...
Ryan.G Posted January 30, 2009 Author Share Posted January 30, 2009 Road legal. Link to comment Share on other sites More sharing options...
Ryan.G Posted January 30, 2009 Author Share Posted January 30, 2009 Ryan, get this entered as a track car over on the TOTB8 thread in Supra Chat Need to get it finished and working right first dude but i will be there with or without the car Link to comment Share on other sites More sharing options...
Ryan.G Posted January 30, 2009 Author Share Posted January 30, 2009 Well no pics tonight guys as i actually left Steve at it as im no good with welders! Tonight he is seam welding in all the floor and most of the cage expect door bars. But tomorrow i will back over, helping to finish the front chassis leg supports and also finishing off the engine mounts At this stage in the project im not much use as i have no experience with welding and grinding etc ..... but i cant wait to get all the floor, engine mounts and the gear tunnel done so i can start making myself useful. Link to comment Share on other sites More sharing options...
supra matt Posted January 31, 2009 Share Posted January 31, 2009 Lovey work Ryan looks very impressive . I see you shortened the prop did you have it rebalanced after ? Link to comment Share on other sites More sharing options...
Ryan.G Posted February 1, 2009 Author Share Posted February 1, 2009 Lovey work Ryan looks very impressive . I see you shortened the prop did you have it rebalanced after ? Oh yes, it will be sleaved and rebalanced Link to comment Share on other sites More sharing options...
Ryan.G Posted February 1, 2009 Author Share Posted February 1, 2009 (edited) Wondering what peoples thoughts are with regards a roof vent as we have a feeling this car is going to be so hot inside that we need all the cooling we can get. Ideally im after a scoop like the Impreza RA has and is closable but cant seem to find any for sale. Like this http://www.scoobypedia.co.uk/index.php/Projects/InstallingASpecCRoofVent http://www.rallispec.com/images_thumb/rst6542.jpg What your thoughts guys Ryan Edited February 1, 2009 by Ryan.G (see edit history) Link to comment Share on other sites More sharing options...
j_jza80 Posted February 1, 2009 Share Posted February 1, 2009 Wondering what peoples thoughts are with regards a roof vent as we have a feeling this car is going to be so hot inside that we need all the cooling we can get. Ideally im after a scoop like the Impreza RA has and is closable but cant seem to find any for sale. Like this http://www.scoobypedia.co.uk/index.php/Projects/InstallingASpecCRoofVent http://www.rallispec.com/images_thumb/rst6542.jpg What your thoughts guys Ryan http://www.writerguy.com/primitive/body.htm There's an aluminium one near the bottom of the page Link to comment Share on other sites More sharing options...
supra matt Posted February 1, 2009 Share Posted February 1, 2009 here are mate http://www.demon-tweeks.com/products/ProductDetail.asp?cls=MSPORT&pcode=AUXRV1 http://www.demon-tweeks.com/products/ProductDetail.asp?cls=MSPORT&pcode=K/CKCRV http://www.demon-tweeks.com/products/ProductDetail.asp?cls=MSPORT&pcode=TOTRVENT Link to comment Share on other sites More sharing options...
Ryan.G Posted February 1, 2009 Author Share Posted February 1, 2009 Thanks Guys Liked the ones on Demon tweak and on driftworks but were just way too much money for what they are. Managed to find a grp version though which was more reasonable priced. http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=220353099461 Link to comment Share on other sites More sharing options...
Ryan.G Posted February 1, 2009 Author Share Posted February 1, 2009 although this isnt my cup of tea, i thought the original scooby doo version looks better, aren't all these scoop type ones going to p**s in if it rains Yh would prefer an RA vent but for how much they are new and 2nd hand its money i could be spending elsewhere tbh. The one i brought looks good on the other car i have seen it fitted on and im buying it more over function than looks. The one i got is a sealable unit and then has a water drain but it wouldn't be stored anywhere outside and on a wet track event i would just point the vents at the passenger Link to comment Share on other sites More sharing options...
Ryan.G Posted February 6, 2009 Author Share Posted February 6, 2009 Update: Gearbox and floor nearly complete , just need to finish off the Engine mounts and mount the pedal box assembly before we can finish the firewall. All the NS4 Aluminium has also been cut to the shapes required to cover the floor from the underside so its all smooth and we also ordered some extra to cover the rest of the bottom of the car so its flat. This we will need to experiment with though as it can be brilliant having the extra downforce but also very bad. Will let Tony explain more about this The gearbox mount has been done also but we are currently looking for some rubber material to make some custom bushes to go between the floot and the mount so the vibration cant damage anything. Anyone got any idea's on this? One thing i will say though is with the new floor and cage the car is rock solid. Ryan Link to comment Share on other sites More sharing options...
Wez Posted February 6, 2009 Share Posted February 6, 2009 Very nice mate While your at it take all the compliance out of the rear subframe, I had mine done while the cage was being fitted Link to comment Share on other sites More sharing options...
