clifford intelliguard 950
chrispot
Chris,
If you can wait till Monday I will send you a document which should help you out.
I used it to uninstall my 950 alarm and refit it so it should be what you need. I have the remote start so it should cover that too.
Thank you, yes i can wait untill monday. if its any good for you i have got original install document for the intellistart which i can copy for you, regards chris
Hi Chris,
I got the images and colour plan from my brother via another website. My brother used these to sort my alarm out and all is well.
Hopefully you should be able to use this to trace the wires to the appropriate alarm control units and feeds into the main loom.
Obviously you use this at your own risk.
Good luck.
Right, here we go:
2 white wires = indicators
orange = negative out whilst armed /not usually needed or used
yellow = horn honk output/not usually needed or used
blue = boot light trigger switch
green= door pins
grey = bonnet pin
black/white = pin 1 = connect to green door pin wire
black/white pin 2 = door pin polarity usually negative
red/white = accessory A
white/blue = accessory B
green/white negative closed loop/ not usually needed or used
blue/white = second unlock output
pink/black = accessory C
purple = + door trigger not usually needed or used
brown/black = unlock 87A
brown/white = brake light input/output
brown/red = 12+ brake input
purple/black = lock 87
green/black = lock 30
violet = unlock 87
blue/black = unlock 30
white/black = lock 87A
