bolarbag Posted November 28, 2008 Share Posted November 28, 2008 Are any of the casings interchangeable, or are the cars limited to their own Diff casings i.e will a Prefacelift Diff fit in a Facelift Diff Casing, or will an N/A diff casing accomadate an Auto or Manual Diff? Quote Link to comment Share on other sites More sharing options...
Nic Posted November 28, 2008 Share Posted November 28, 2008 (edited) The Supra was fitted with 2 different diff casings, left is an early model 6spd TT diff (B), right is the smaller diff (A) used on ALL other Supra models, including the facelift 6spd TT. They are interchangeable, but if you swap between the 2 different types, then you also need to replace the rear driveshaft as they are different lengths. If you are swapping between models eg. auto/manual, NA/TT, J-spec/UK spec then the final drive gearing will be different. http://img210.imageshack.us/img210/2994/supravsoarerex8.jpg View from opposite side http://img177.imageshack.us/img177/5899/supravsoarer2ds2.jpg Edited November 28, 2008 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
bolarbag Posted November 29, 2008 Author Share Posted November 29, 2008 Thanks Nic just what I was looking for! Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 29, 2008 Share Posted November 29, 2008 3 casings actually, the UK / US spec ones have drillings and tappings for the diff oil cooler plumbing, but is essentially the same. Quote Link to comment Share on other sites More sharing options...
halllon Posted September 3, 2009 Share Posted September 3, 2009 They are interchangeable, but if you swap between the 2 different types, then you also need to replace the rear driveshaft as they are different lengths. Exactly what are the differences between the driveshafts? We are swapping to a large casing diff and need to know if one or both of our drive shafts will have to be replaced. Our car does also have ABS hubs and the donor car with the large casing diff does not have ABS hubs. Will the parts fit? Quote Link to comment Share on other sites More sharing options...
