Brainteaser....
scooby_doo_do
3 x Barrels
1 x Barrel with 100 x Black balls
1 x Barrel with 100 x White balls
1 x Barrel with 50 x Black balls 50 x White balls
Each barrel has a label which could be "Black Balls Only", "White Balls Only", "Black or White Balls", but the barrels have the incorrect label.
How many balls need to be extracted before you can identify the correct label for each barrel?
I've got it, it's because it says the barrels HAVE the incorrect label, not may have. So the one that says "black or white balls" must actually have either all white balls or all black in. So you take one ball from that barrel. If it's white the correct label for that barrel is "white balls". If it's black the label is "black balls". Then just swap the other two barrel labels round.
