What gauges for my 3 gauge pod?
rick001
Boost, oil pressure,EGT then use the airvent next to the clock for your AFR gauge
Personally I prefer oil temp to oil pressure.
It's nice to have an idea of when the engine is warmed up, the water temp gauge is of little use for this.
Won't there be a warning for low oil pressure on the Supra anyway?
EGT, Oil temp and Water temp if it were me. Most owners who are at the stage of extra gauges would have a boost controller which have boost gauges built in.
I'd do the above as well^^
..hang on - where did you get a 3 gauge A pillar pod from? :search:
From brett that where he got from ;)
Thanks for the advice guys, got the pod from, as the man said, Brett - great bit of kit too
I have boost, EGT and AFR. But mine was a 2 guage pod i added an extra smaller pod to for the AFR.
I previously had the boost in the vent near the clock which was good but i missed the air at that side. And i use the clock all the time as i dont use a watch so didnt want to loose it.
