Uprated Anti Roll Bars
JamieP
I love my Superstreets because they are soft and give a great ride on our bumpy roads but would like a little less body roll, will the antiroll bars make for a harsher ride? if so i will live with a bit of body roll.
No the roll bar dose what it sez on the tin and dose not effect straight line driving at all .
I was told (can't remember who off now) that the adjustability of the ARBs on road cars like ours is a bit of a gimick. They're too heavy, & the distance between the 3 adjustment points is so close that it makes no difference. The cars would need to be much lighter (Elise/Caterham sort of weight) and bigger adjustment distances would be needed to make the adjustments noticable. Any knowledgable suspension people confirm/disconfirm (??) this
I'm planning on TRD ARBs sometime. Quality is top notch.
I confess I'm a little sceptical about Titan ARBs as they sounds excessively stiff - remember that titan are known for drag racing, not road/track racing.
You dont need roll bars for drag racing. Here's the tech info on the Titan roll bars
Front Sway Bar (2 way adjustable)
Light Setting 8% stiffer then TRD 498.9 lbs/in
Heavy Setting 27% stiffer than TRD 584 lbs/in
Rear Sway Bar (3 way adjustable)
Light 18% softer then TRD 367 lbs/in
Medium 6% Stiffer than TRD 458 lbs/in
Heavy 35% Stiffer than TRD 588 lbs/in
