Dan8 Posted November 23, 2008 Share Posted November 23, 2008 Right i am about to put it away to next spring and whilst its away i am changing a few things and have a few questions for use i am changing the both belts and want to know where i can get hold of the tool to remove the bottom pulley where from and how much are the fuel filters What size and amps the battery as mines about had it and the labels pealed away and how much should i pay i need to change both front wheel bearings is this easy enough with normal tools and have you got the relavant torque settings i will require where can i get a donut rubber as every now and then when i set away it seems to judder or as if its tramping it has a l s d and the oils at right level cheers for any help Quote Link to comment Share on other sites More sharing options...
