Car wont start !
Dyer864
Hi all !
Got in car today, turned ignition click, click nothing !
dash lights all bright, windows go up & down ok , lights work. havn't used car since weds. would it be battery surely it would have drained the lights etc, any ideas :search:
poss starter motor giving it a tap may release it.
also try a booster pack to double check its not the battery
if the starter motor won't even crank over but all other electrical functions work, then its not the battery.
Check the fuse for the starter motor, check the wires leading to and from starter, and CHECK THE KEYHOLE coz mine had that problem, due to wear and tear, one of the wires there broke off :)
CHEERS!
Buy a multi-meter and check your battery. If it's going click, click then the solenoid is kicking in but there might not be enough juice left in the battery to turn over the starter motor. Doesn't mean that the basic electrics won't work as they draw a lot less current.
If you're getting a click when you try to turn the car on then its the starter. You just need to whip it off and change the contacts, should be as good as new.
apart from just whipping it off is actually an annoying task . mine still need doing although its starting better recently so putting it off
There's a guide on here somewhere on how to do it. Do a search for "starter motor refurb" or similar. Depends how good you are with the spanners as to whether it's worth doing yourself. Having a hydraulic jack and decent axle stands is a must I would think. I looked into doing it myself, but decided against it after reading the guide.
