still knocking from rear!
dcarrter21
It's definitely not the boot in my car. The sound is coming from much lower down.
It may well be your exhaust pipe "wanging" (is that a word?) about at the rear bumper.
Mine knocks a bit a low speeds & over speed bumps etc...but get the old girl up to a decent rate and it smoothens out nicely :)
Edited by Lbm (see edit history)
Mine knocks from both side and no one can find the problem, I have not bought top mounts yet thou, My mechanic said his mate with a supra has a knock both sides from the rear and he cant find what it is, I just turn the stereo up more Because i cant be arsed spending money on people looking at it and saying they dont know whta it is, Ive tried three good import specialist upto now. We should all get together And have a big head scratch at it.
Just another thought came to mind as a quick/cheap diagnosis / elimination, try removing the Anti-Roll Bar Bushes and clean/grease the contact area that Anti- Roll bar the bush rubs on. -(and the hole inside the bush) Poss due to Dirt/Age bush getting a bit worn /slack or poss sticking/too much friction?.
this might be worth a look, if you have an after market exhaust fitted? check that it is not hitting on a small cross member/bar that protects the exhaust hitting the propshaft.
sorry i can't describe it better but i know that when i had my car up on a ramp last weekend i noticed that the bar had been bent away from the exhaust, it's to the rear of the prop.
Guest sodbuster
Im having the exact same problem with my 95 NA!! nobody can seem to find the source of the knocking noise and im worried that if i start forking out money for new suspension bits.. that ill end up replacing everything and still have the noise!
*Ive had all brakes changed
*new tyres
*tightened subframe bolts
*checked wheel nuts
*had new exhaust fitted that's not rubbing on underneath
*a garage has checked the suspension and said that all bushes are ok
Please help!
P.S.. i wonder if my new two tone leather seats will help next week?!?! :D:D:D lol
May possibly be the Rear Anti- Roll Bar Bushes or the Drop Links that are attached to the Rear Anti- Roll Bar? had similar problem on my N reg corolla.
I have the same issue and have also tried everything. Even had Toyota re-torque everything in the suspension. I would love to check the anti-roll bars myself though, but what is the Drop Links?
i mite try the antiroll bar then. my boot was sqeeking but that got sorted with some rubber strips. how much are new roll bar bushes?
New role bar bushes are cheap.
Aschris said just undo the drop links and tie them out the way and go for a drive on a bumpy road.
Come round on the weekend if you want aslong as its not raining and we can do it then.
