marc_p Posted November 23, 2008 Share Posted November 23, 2008 Ok, my old civic has been stood for a while and today I have put a new battery in it as there was no battery in it and it started perfectly before(about 7 months ago) but now when you turn the key to start it all you hear is the fuelpump whine but nothing else whatsoever, I don't really know what it could be, any ideas? Quote Link to comment Share on other sites More sharing options...
Steve Posted November 23, 2008 Share Posted November 23, 2008 Have you checked all the fuses. Maybe spiked something with the new battery being connected. Quote Link to comment Share on other sites More sharing options...
marc_p Posted November 23, 2008 Author Share Posted November 23, 2008 Have you checked all the fuses. Maybe spiked something with the new battery being connected. Good idea, I'll go check now and report back;) Quote Link to comment Share on other sites More sharing options...
Dazzi Posted November 23, 2008 Share Posted November 23, 2008 Did you put new fluids in or was the car sitting with old? Also did you break a mirror, walk under a ladder... run over a black cat? Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted November 23, 2008 Share Posted November 23, 2008 have you tried new plugs ? Quote Link to comment Share on other sites More sharing options...
marc_p Posted November 24, 2008 Author Share Posted November 24, 2008 Ok, all fuses are fine. have you tried new plugs ? Wouldn't it still try and turnover with old plugs though? I do have some spare plugs I can try, well I have spare engine, gearbox, everything basically. Could it be the starter motor? Quote Link to comment Share on other sites More sharing options...
adnanshah247 Posted November 24, 2008 Share Posted November 24, 2008 hit the starter motor a few times with a hammer, check the battery terminals. if not try push starting it to get the things moving. Quote Link to comment Share on other sites More sharing options...
Guest banjo_bob Posted November 25, 2008 Share Posted November 25, 2008 If there is a spade connector on the starter, pull off and push back on again ( thin wire, signal wire to starter solenoid) Very common on a lot of cars to loose the connection due to corrosion etc. Could also be the starter relay, but try the above first. Spark plugs won't stop it turning over unless one is in the engine and jamming a piston Quote Link to comment Share on other sites More sharing options...
Duffman Posted November 25, 2008 Share Posted November 25, 2008 hit the starter motor a few times with a hammer, check the battery terminals. if not try push starting it to get the things moving. Quote Link to comment Share on other sites More sharing options...
Kranz Posted November 25, 2008 Share Posted November 25, 2008 I was going to say bump start it as this should free off whatever it is that's preventing it starting. Quote Link to comment Share on other sites More sharing options...
Guest banjo_bob Posted December 20, 2008 Share Posted December 20, 2008 Any conclusion to this? Quote Link to comment Share on other sites More sharing options...
Guest CoolsBlue Posted December 20, 2008 Share Posted December 20, 2008 Any conclusion to this? you should of bought a supra Quote Link to comment Share on other sites More sharing options...
