SUPRALOOPY Posted November 22, 2008 Share Posted November 22, 2008 Bit of a funny one this. You start it up and it starts but then dies and will not start again (as if its run out of fuel) But if you give it a sniff of etha it will start after a while and then be fine? I thought it was fuel running back past the one way valves and then sucking air but I believe this would take some time I:E overnight. But this can do it within hours or days. When you plug it in it brings up a glow plug error but I believe this is due to the none start fault and causing this code. Has anybody had any run ins with deisel vectra duratec turbo engines and have any of you come across this before? I will go down the normal channels but I thought I'd ask any way. Thanks Dave:) Link to comment Share on other sites More sharing options...
absz Posted November 22, 2008 Share Posted November 22, 2008 Sounds like low fuel pressure delivery the pump is a common fault on them, but you can try and have a look at the injector seals and bleed off pipes to make sure there is no leaks. Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted November 22, 2008 Author Share Posted November 22, 2008 I had suspected the pump, but need to be sure before I tell the customer his car is basicly fooked due to cost. Bleeds and seals are my next check. But if the pumps are a common fault then I bet thats what it is! Thanks absxxxx Dave Link to comment Share on other sites More sharing options...
Kranz Posted November 22, 2008 Share Posted November 22, 2008 This may not be a great idea, but can you put a low pressure (under 1 bar) feed to the dirty side of the fuel filter to see if the pressure increase cures it?? Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted November 22, 2008 Author Share Posted November 22, 2008 I will try all this Monday. I'm just fishing ATM just in case someone has had this problem before, I'll go down the normal route of elimination but just thought I could cheat..LOL Any more Ideas would be great..Thanks Dave Link to comment Share on other sites More sharing options...
absz Posted November 23, 2008 Share Posted November 23, 2008 This may not be a great idea, but can you put a low pressure (under 1 bar) feed to the dirty side of the fuel filter to see if the pressure increase cures it?? you can fit a inline electric fuel pump to increase pressure but haven't tryed this myself:innocent: Link to comment Share on other sites More sharing options...
