Cut ABS sensor wire
Homer
Almost forgot about this bit! One of the ABS sensor lines has been cut near the rear wheel, is it possible to simply patch it back together or will that screw up the signal? I heard that the ABS sensors are VERY sensitive and heavily sheilded so not sure if it's advisable to repair..
TIA :)
Try and see mate? check after you have done this the resistance between the sensor and the block connector with one that has not been repaired and see the differance.
If they are the same then thats good enough I think. Its only a square wave signal anyway so should not be a problem.
After the wiring comes out of the strut tunnel it goes to unshielded wire so you should be alright if you repair it nicely Daryl. But if you are worried about it you can borrow my Scope to check the signal sometime.
Ryan
Thanks Ryan, very nice of you to offer. The cable out of the hub is heavily shielded so was worried about interference. Will try and do a good job on it but if things go wrong I'll take you up on the offer!
ABS is one of those things you don't want to get bugger up at the wrong moment hence the caution..
if you have RLTC to could use that to make sure you are getting a valid signal, either way if i were you i would want to know the signal is good, out of interest would a duff sensor not flag up a fault code ?
No RLTC (It's an NA :D)
Apparently a duff (or in this case missing) sensor doesn't throw up a fault code on the ECU, but the ABS warning light stays on.
The ABS unit stores fault codes much like the ECU does, you can read them off and get which bit is playing up.
Have a search, I think I've mentioned it a couple of times in the past :)
-Ian
Thanks Ian, thats really good to know :) I'll go have a search
