Pick up my tt 6speed tomorrow!!!! Yippee!!!
scotty supra
well i found the best way to clean the headlights and with out damaging them or taking them out etc,
is G4 rubbing compound, i checked it out on my mates headlights as there were driving my mad seeing them going yellow / and more yellow lol.
and now they have came up a treat.
Best way to use the compound is give car a good wash first and dry, make sure there is no water around the rubber etc, then in small circles apply the compound leave for roughly 5 / 10mins and rub off, using the method of small circles, when all compound is removed then like you would when polishing buff up the and watch the difference. Straight away you should notice a difference compared to the other head light if done properly. I done my mate's head lights a couple of times,
I found this is easier then messing around with trying to take headlight out etc.
Just thought i would share this with you guys lol.
Plus the G4 Compound can be use for any body work and will get stratchs / marks etc out as well which i found.
