ABS warning light and RLTC don't mix
Graham Rudd
After a spirited blast trying to race a bike from a set of lights (I lost) I had to brake HARD to make my turn off. Imagine my suprise when I manged to lock the wheels up, no sign of the ABS kicking in. After getting down to a sensible speed I noticed, not suprisingly, the ABS warning light was on.
The next shock came when I tried to accelerate and the engine just died on me. Luckily I realised immediately what was going on and turned off the RLTC which was obviously getting garbage signals from the ABS sensors.
I've noticed though that the ABS warning light now always seems to be on whenever the weather is hot! I can live without the ABS unit, but not the RLTC. Has anyone got any idea what could be causing it to only fail when the sun is shining!?
Thanks
Graham
I've checked the connections behind the dash Phil, all *seem* to be fine. Another development though, also had the brake warning light come on now. Definately seems to be an electrical problem somewhere, and it definately seems to be heat related.
Matt, checking the sensors... sounds a bit mechanical to me, I don't do mechanical! ;) I will make a point of carrying my laptop to work with me now though on the offchance that the ABS light is on for the journey home so I can grab a look at the wheel speed trace.
[OT] I know its been a long time coming Phil, but I'll have a new version of the TC software for you to have a play with very shortly. (my workload has eased up a little so I've had a chance to play)
I'm pretty sure its ambient heat. Never happens on a morning, and I've seen it quite a lot of times now leaving work if I leave the car in direct sunlight during the day.
I've tried leaving it in the shade as a test a few times and haven't seen the warning light come on.
The incident with the ABS cutting out on me whilst actually driving is the only time its ever happened mid-journey. But I will have been piling an AWFUL lot of heat into the vicinity of the wheels.
Its been happening for a long time, but the mid-journey one has prompted me to try to get it sorted! :rolleyes: I just don't fancy paying for a garage to find an electrical problem though, god knows how long it could drag out for and I don't want to remortgage the house just to have ABS ;)
Cheers
Graham
As it's affecting both the ABS and the RLTC I would suspect its a problem at the ABS Sensor end (or wiring to it), if it was just the ECU you would expect the RLTC to still work as it is taking the sgnal from the sensors not from the ECU. It could also be the connector on the ECU depending on how the ECU sensors are wired up. Like it has been said check the ABS signals with the diagnostic light on the RLTC, if it's just one sensor thats out I would suspect it's downstream from the ECU if it's all of them it's more likely to be the ECU.
It looks like it might well be a dodgy ABS sensor. Its the near side front wheel sensor that seems to be acting up. I don't suppose anyone would have a part number for it?
I guess I should have a look at it to see if their is anything obviously wrong, but my innate incompetence at mechanical tasks is putting me off. I figure I'll just pay someone to stick a new one one :)
Cheers
Graham
