Supradoopa Posted November 21, 2008 Share Posted November 21, 2008 i lost 36 calories last night Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted November 21, 2008 Share Posted November 21, 2008 All rolls royce (original not german) use imperial due to the fact that its still aircraft based. All aircraft with rolls royce engines are imperial sizes(don't know about all aircraft but I'll soon be told I bet) Link to comment Share on other sites More sharing options...
Tannhauser Posted November 22, 2008 Share Posted November 22, 2008 Some really good points raised there even one from a guy that visited the same place i did and confirms that there is no slight of hand, funny shaped bolws or any other dodgy business going on, i suppose what would be useful now is for one of the Aussies to run a sink and let that drain and i do the same and if the both go the same way then fine case closed. However i still stand by what i saw and they never had specially designed basins it was a bucket and funnel and match. richie In the notorious Project Alpha scam, James Randi paid two young proteges to infiltrate the University of ??? (Washington??) paranormal research unit - funded with a bidget of several hundred thousand dollars. They kept the scientists convinced for several years. The point being that even a team of sceptical, highly intelligent and educated scientists can be mistaken about what they are seeing - if you don't know exactly what you're looking for you don't have a hope in hell of figuring it out. It's difficult to discount the evidence of your own eyes, but magicians regularly do things in front of street audiences, often with the minimum of equipment, that we know must be impossible. I suggest that this is the same thing. Link to comment Share on other sites More sharing options...
Supra-Brett Posted November 22, 2008 Share Posted November 22, 2008 The furthest distance ever travelled by a cow in a tornado is 14miles. Link to comment Share on other sites More sharing options...
Tannhauser Posted November 22, 2008 Share Posted November 22, 2008 I would think permanent bowls would be even easier to tamper with, but never mind. The fact is the coriolis effect is caused because (in simple terms) the equator is travelling east at just over 1000mph, and the north pole is travelling east at 0mph, so the further north you go the slower you are travelling eastwards. Therefore a large body such as a hurricane will begin to spin in an anti-clockwise rotation in the northern hemisphere because it's southernmost point is travelling eastwards quicker than it's northernmost point is. the difference in easterly velocity of a 2 litre jug of water will have such a tiny effect that it is FAR outweighed by other factors, such as the shape of the bowl and forces exerted on it by humans. Sorry. I've just had a quick go at calculating this. Anyone with decent maths/physics will probably take apart my shonky methods/assumptions, but here goes. The question is, how much slower would the most northerly part of the water in a plughole vortex be travelling than the most southerly part, due to the Earth's rotation (if you're in the northern hemisphere)? OK, the Earth is 40,000km in circumference. Therefore it is 10,000 km from equator to axis of rotation (i.e. north pole, or thereabouts). The equator is moving at 40,000km/day = 462m/s, whereas at the pole, you're simply spinning like a top = 0 m/s. So for every 1 km travelled North, you are travelling 462/10,000 m/s = 0.0462m/s more slowly. The most northerly section of a 100km hurricane would be travelling at 4.62m/s slower than the southern part. How about some water just above a 5cm plughole? The difference between how quickly the northern side and southern side are rotating is presumably 0.00005km * 0.0462 = 0.0000023m/s. That's a difference of two millionths of a metre a second (= two thousandths of a millimetre per second). Without knowing much about it, on the surface this sounds pretty insignificant to me and, as Trev says, not really enough to cause any sort of effect. Link to comment Share on other sites More sharing options...
AndrewOW Posted November 22, 2008 Share Posted November 22, 2008 I've just had a quick go at calculating this. Anyone with decent maths/physics will probably take apart my shonky methods/assumptions, but here goes. The question is, how much slower would the most northerly part of the water in a plughole vortex be travelling than the most southerly part, due to the Earth's rotation (if you're in the northern hemisphere)? OK, the Earth is 40,000km in circumference. Therefore it is 10,000 km from equator to axis of rotation (i.e. north pole, or thereabouts). The equator is moving at 40,000km/day = 462m/s, whereas at the pole, you're simply spinning like a top = 0 m/s. So for every 1 km travelled North, you are travelling 462/10,000 m/s = 0.0462m/s more slowly. The most northerly section of a 100km hurricane would be travelling at 4.62m/s slower than the southern part. How about some water just above a 5cm plughole? The difference between how quickly the northern side and southern side are rotating is presumably 0.00005km * 0.0462 = 0.0000023m/s. That's a difference of two millionths of a metre a second (= two thousandths of a millimetre per second). Without knowing much about it, on the surface this sounds pretty insignificant to me and, as Trev says, not really enough to cause any sort of effect. That's all very well, but will the plane take off?! (Very interesting stuff though) Link to comment Share on other sites More sharing options...
SilverSoop Posted November 22, 2008 Share Posted November 22, 2008 A passenger jet aircraft stretches during flight when cruising... Link to comment Share on other sites More sharing options...
jamesmark Posted November 22, 2008 Share Posted November 22, 2008 No piece of paper can be folded in half more than 7 times. That is a myth, they done it on Mythbusters folded a peice of paper more than 7 times. Quite a few videos of it getting done on youtube too Link to comment Share on other sites More sharing options...
Supra-Brett Posted November 22, 2008 Share Posted November 22, 2008 The weight in soil pushed by a moles front feet, is the equivelent of a pigeon pushing two pigs out of its nest !!!!! Link to comment Share on other sites More sharing options...
Dann Posted November 22, 2008 Share Posted November 22, 2008 when you sneeze your heart stops for a split second thats why people say bless you. Link to comment Share on other sites More sharing options...
jamesmark Posted November 22, 2008 Share Posted November 22, 2008 Proof that paper can be folded more than 7 times. http://uk.youtube.com/watch?v=JjMA6ZIla00&NR=1 Seriously look closely. Link to comment Share on other sites More sharing options...
Gaz Walker Posted November 22, 2008 Share Posted November 22, 2008 Proof that paper can be folded more than 7 times. http://uk.youtube.com/watch?v=JjMA6ZIla00&NR=1 Seriously look closely. Busted I didn't check though, but it was one of those things one assumes to be true Link to comment Share on other sites More sharing options...
jamesmark Posted November 22, 2008 Share Posted November 22, 2008 Busted I didn't check though, but it was one of those things one assumes to be true The video only shows 7 mate, it was more along the lines of the distraction the in the background Link to comment Share on other sites More sharing options...
Gaz Walker Posted November 22, 2008 Share Posted November 22, 2008 The video only shows 7 mate, it was more along the lines of the distraction the in the background I know that ( nice try though ) Link to comment Share on other sites More sharing options...
Lbm Posted November 22, 2008 Share Posted November 22, 2008 Mark Webber is better at driving than cycling. Link to comment Share on other sites More sharing options...
SilverSoop Posted November 22, 2008 Share Posted November 22, 2008 Mark Webber is better at driving than cycling. Cruel but true... Link to comment Share on other sites More sharing options...
GreaseMonkey Posted November 22, 2008 Share Posted November 22, 2008 WD-40 literally stands for Water Displacement, 40th attempt. That's the name straight out of the lab book used by the chemist who developed WD-40 back in 1953. The chemist, Norm Larsen, was attempting to concoct a formula to prevent corrosion -- a task which is done by displacing water. Norm's persistence paid off when he perfected the formula on his 40th try. The opposite of a Vacuum is a Plenum. Alexander Graham bell never phoned his wife or mother as they (His Wife and Mother) were both Deaf. Link to comment Share on other sites More sharing options...
michael Posted November 22, 2008 Share Posted November 22, 2008 When the water in your bucket starts freezing it's time to stop washing the car. Link to comment Share on other sites More sharing options...
tbourner Posted November 22, 2008 Share Posted November 22, 2008 Boiling water freezes quicker than cold water. Actually, I need to look into this one cos I heard it and assumed it was true, it might be one of those things that's bandied around as fact and is actually hogwash! Link to comment Share on other sites More sharing options...
Max Headroom Posted November 22, 2008 Share Posted November 22, 2008 Time flies like an arrow, fruit flies like a banana!! Link to comment Share on other sites More sharing options...
benkei Posted November 22, 2008 Share Posted November 22, 2008 Boiling water freezes quicker than cold water. Actually, I need to look into this one cos I heard it and assumed it was true, it might be one of those things that's bandied around as fact and is actually hogwash! Yeh, it's true, something to do with the density of it I think? Link to comment Share on other sites More sharing options...
Pot Posted November 22, 2008 Share Posted November 22, 2008 Boiling water freezes quicker than cold water. Yeh, it's true, something to do with the density of it I think? I've heard that too, I would offer to try it out, but I've just filled my freezer up and it took me ages to pack it all into place... All a part of living on less than a million pounds a year, else I'd have paid some other f**ker to load my freezer for me Link to comment Share on other sites More sharing options...
AndrewOW Posted November 22, 2008 Share Posted November 22, 2008 Yeah, the atoms in water are more unstable at hotter temperatures, than cold water, and so allow the cold to penetrate and freeze it quicker. Allegedly. Or something like that. Link to comment Share on other sites More sharing options...
RobSheffield Posted November 22, 2008 Share Posted November 22, 2008 Yeah, the atoms in water are more unstable at hotter temperatures, than cold water, and so allow the cold to penetrate and freeze it quicker. Allegedly. Or something like that. Interesting. Actually no it isnt! Link to comment Share on other sites More sharing options...
AndrewOW Posted November 23, 2008 Share Posted November 23, 2008 Interesting. Actually no it isnt! Sorry, and that's a fact. Link to comment Share on other sites More sharing options...
