MR 2 turbo starting problems--please help
alaing
After changing the waterpump, my car will not start! Ive checked and double checked that the timing marks line up in the right places so pretty sure its not that. Its throwing a fault code 51. I did try to start her with the boost pipes off and i have read this causes problems. I may have flooded the engine? but any other idea would be a help thanks.
Heres what it says in the bgb, but im having trouble understanding what it means?
What is the IDL circuit
what is a switch condition signal
This fault comes up even after a ecu re-set please help thanks.alain
Thanks guy I dont think i have lent on the tps or wires ? Testing it now, It may have to be replaced but seems weird as was workin fine b4 i took the water pump off! Im 99% sure the cam belt is on right as have done one in a celica turbo before no porblems. Still anymore inout is great!
