Neil Sandham Posted September 4, 2002 Share Posted September 4, 2002 As a UK spec, mine will obviously be tested as a car with cats. Does anyone know/have experience of if I need to put both cats back on, or will I get away with just putting one back on in order to squeeze in the emmission regulations ? cheers Neil. Link to comment Share on other sites More sharing options...
GavinL Posted September 4, 2002 Share Posted September 4, 2002 Originally posted by Neil Sandham As a UK spec, mine will obviously be tested as a car with cats. Does anyone know/have experience of if I need to put both cats back on, or will I get away with just putting one back on in order to squeeze in the emmission regulations ? cheers Neil. Just stick the small back in and you should be fine. Link to comment Share on other sites More sharing options...
Keith C Posted September 4, 2002 Share Posted September 4, 2002 Yup - mine sailed through a couple of weeks ago with only no.2 cat in. Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 4, 2002 Share Posted September 4, 2002 Originally posted by Neil Sandham As a UK spec, mine will obviously be tested as a car with cats. Does anyone know/have experience of if I need to put both cats back on, or will I get away with just putting one back on in order to squeeze in the emmission regulations ? cheers Neil. Just refit the rearmost cat (4 bolts and the 2 nuts for the 2nd O2 sensor) and it will easily pass. the first cat is there to pass emissions in some other countries where the cat has to be up to temp very quickly (30 seconds i think), hence they bung one as near the pots as possible, and with a low honeycomb volume to heat up fast. Link to comment Share on other sites More sharing options...
Neil Sandham Posted September 4, 2002 Author Share Posted September 4, 2002 Cheers, I'll let you know how it goes on Friday! Why do MOT's always make me feel sooooo nervous ! Neil Link to comment Share on other sites More sharing options...
Neil Sandham Posted September 6, 2002 Author Share Posted September 6, 2002 Well, the good news is, it passed ! but only just. The tester said it was "just" inside the legal emmisions. Here are the numbers for you to compare yours against. First Test - Fast idle 2400 rpm (Engine cool) CO % .70 (fail) HC 69 ppm (pass) lambda 1 (pass) Second test - Fast Idle 2400 rpm (Engine hot) CO % .29 (pass) limit is apparently 0.3% HC 35 ppm (pass) Lambda 0.99 (pass) Natural Idle (engine hot) CO % 0.04 (pass) Cheers Neil. Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 6, 2002 Share Posted September 6, 2002 Originally posted by Neil Sandham Well, the good news is, it passed ! but only just. The tester said it was "just" inside the legal emmisions. Here are the numbers for you to compare yours against. First Test - Fast idle 2400 rpm (Engine cool) CO % .70 (fail) HC 69 ppm (pass) lambda 1 (pass) Second test - Fast Idle 2400 rpm (Engine hot) CO % .29 (pass) limit is apparently 0.3% HC 35 ppm (pass) Lambda 0.99 (pass) Natural Idle (engine hot) CO % 0.04 (pass) Cheers Neil. I was out on the town with my MOT testing station owning pal last night and he was telling me recently the MOT emissions regs have changed. i am getting him to print off the relevant pages, basically a "BETS" test is done, a "Basic Emissions Test". If there is no hard data on the car (like ALL Suzukis, believe it or not..., and most imports), then the machine allows you to scroll through to a much more liberal tst (3.5% CO I think), which any catless Supra should sail through. I may be a bit out on the facts but I'll get the details and post them soon. Link to comment Share on other sites More sharing options...
Adam W Posted September 6, 2002 Share Posted September 6, 2002 Sounds like a wild night out Chris . . . . It seems strange that the Government has formally recognised the loophole in this way and yet is making no effort to close it by ensuring vehicles are correctly classified. Link to comment Share on other sites More sharing options...
Mark Kindell Posted September 6, 2002 Share Posted September 6, 2002 Just a note but i am a curent M.O.T. tester and if anyone needs their car MOT'd then i'm in Aylesbury Bucks Link to comment Share on other sites More sharing options...
