uabb Posted November 19, 2008 Share Posted November 19, 2008 Join Date: Sep 2008 Location: Denmark Posts: 7 Sales Feedback: 0% (0) Big problems ..... -------------------------------------------------------------------------------- Hi and sorry. I have problems whit my supra n/a. i drive manue4l on and automatik gearcaase and when i wont to shioft to sekond gear it goes out ... like you toke the key out. she died. My fuelpump goes and there are egnicenkontakt, but it will not start ? ... sorry my english is not so got, but i will hope some one cut help me. regards kim from denmark Quote Link to comment Share on other sites More sharing options...
Homer Posted November 19, 2008 Share Posted November 19, 2008 The first thing to check for would be error codes (click the link) Does it cut everything, i.e the engine stops completely? Does the car restart okay after it's been stopped? Seems like quite an odd problem! Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 20, 2008 Share Posted November 20, 2008 Sounds like it COULD be the neutral lock out switch or connector on the side of the gearbox. Is this the biggest problem Denmark is facing? We have a recession here, I think I'll move... Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted November 20, 2008 Share Posted November 20, 2008 Is this the biggest problem Denmark is facing? We have a recession here, I think I'll move... Quote Link to comment Share on other sites More sharing options...
RedM Posted November 20, 2008 Share Posted November 20, 2008 Please keep chat and smileys out of technical. Thank you. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 20, 2008 Share Posted November 20, 2008 What a cold and sterile place this has become Quote Link to comment Share on other sites More sharing options...
RedM Posted November 20, 2008 Share Posted November 20, 2008 What a cold and sterile place this has become It's what IanC would've wanted. Quote Link to comment Share on other sites More sharing options...
Scooter Posted November 20, 2008 Share Posted November 20, 2008 What a cold and sterile place this has become try not to let it bother you........ It's what IanC would've wanted. possibly but it's in the delivery........this is how it's done Quote Link to comment Share on other sites More sharing options...
uabb Posted November 20, 2008 Author Share Posted November 20, 2008 Hi. It´s stop an will not start again .... i can hear the fuel pump, I can se ignision on the .,.. sparks .... bur it still wont to drive ;0) Regards Kim Quote Link to comment Share on other sites More sharing options...
Dazzi Posted November 20, 2008 Share Posted November 20, 2008 (edited) When was the last time you replaced your clutch? Is there any gearbox grinding/noise? Does it shift ok? Edited November 20, 2008 by Dazzi Edit: Saw its auto (see edit history) Quote Link to comment Share on other sites More sharing options...
D8MOA Posted November 20, 2008 Share Posted November 20, 2008 When was the last time you replaced your clutch? Is there any gearbox grinding/noise? Does it shift ok? think the cars a auto! Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted November 21, 2008 Share Posted November 21, 2008 Hej Uabb Prøv at hoppe ind på http://www.sonid.dk og skriv et indlæg i det forum der er for ikke-medlemmer. Måske nogen kan hjælpe dig der? Quote Link to comment Share on other sites More sharing options...
absz Posted November 21, 2008 Share Posted November 21, 2008 Hej Uabb Prøv at hoppe ind på http://www.sonid.dk og skriv et indlæg i det forum der er for ikke-medlemmer. Måske nogen kan hjælpe dig der? yep i agree:d Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted November 21, 2008 Share Posted November 21, 2008 Thought you might just told him to contact the danish supra club. might be a bit easier and maybe there is someone close by that could take a look at the car Quote Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted November 21, 2008 Share Posted November 21, 2008 Thought you might just told him to contact the danish supra club. might be a bit easier and maybe there is someone close by that could take a look at the car We knew that... Quote Link to comment Share on other sites More sharing options...
uabb Posted November 21, 2008 Author Share Posted November 21, 2008 The first thing to check for would be error codes (click the link) Does it cut everything, i.e the engine stops completely? Does the car restart okay after it's been stopped? Seems like quite an odd problem! Yes it´s stop, an in can start again. The moter turn around but no live ? Thanks Kim:taped: Quote Link to comment Share on other sites More sharing options...
uabb Posted November 21, 2008 Author Share Posted November 21, 2008 Sounds like it COULD be the neutral lock out switch or connector on the side of the gearbox. Is this the biggest problem Denmark is facing? We have a recession here, I think I'll move... Thanks ..... in Denmark but it´s a big problem for me[OOPS][/OOPS] Kim in Denamrk Quote Link to comment Share on other sites More sharing options...
uabb Posted November 24, 2008 Author Share Posted November 24, 2008 When was the last time you replaced your clutch? Is there any gearbox grinding/noise? Does it shift ok? Hi.... They are new and it´s shift okay .. and now noise... Kim Quote Link to comment Share on other sites More sharing options...
