Luka-P Posted November 19, 2008 Share Posted November 19, 2008 After my little Fezz blew its guts out over the M60 last night I decided I'd go on the hunt for a little workhorse. I've found a Berlingo 1.9 on a 2002 plate but it has a bit of a problem. Its blowing a fair amount of smoke through the exhaust which leads me to think its the head gasket? Its had alot of work on it recently but the guy wanted rid. There's no mayo on the oil filler cap. It starts and drives but with not much power and lots of smoke. Its with me now, towed it home. Any ideas? Luke Quote Link to comment Share on other sites More sharing options...
peter richards Posted November 19, 2008 Share Posted November 19, 2008 could be bent valves , not sure how similar to my old kangoo it is , but after the aux belt got under the timing belt it was never the same huge loss of power and smokey , Quote Link to comment Share on other sites More sharing options...
Luka-P Posted November 19, 2008 Author Share Posted November 19, 2008 Its only just started doing this apparently and had the cambelt done recently. Ill probably pull the head off tomorrow, check the valves and gasket. Anything else I might need to look into? Its had new injectors recently also. Quote Link to comment Share on other sites More sharing options...
pete.w Posted November 19, 2008 Share Posted November 19, 2008 egr valve ? or the timing on the cam belt hasunt been set up correctly causeing unburnted diesel makeing the smoke . Quote Link to comment Share on other sites More sharing options...
Luka-P Posted November 19, 2008 Author Share Posted November 19, 2008 I dont think its a timing issue. It ran ok after the belt was changed but then this began all of a sudden. Could be EGR but I dont think it would smoke that much. Its more of a plume! Quote Link to comment Share on other sites More sharing options...
edge Posted November 19, 2008 Share Posted November 19, 2008 Would move onto the next van forsale. Quote Link to comment Share on other sites More sharing options...
Luka-P Posted November 19, 2008 Author Share Posted November 19, 2008 I value your opinion but I think Ill try and fix this one to be honest. Quote Link to comment Share on other sites More sharing options...
gordy07 Posted November 19, 2008 Share Posted November 19, 2008 My vauxhall combo(05)smokes like a chimney and only has 27000 miles:blink: Quote Link to comment Share on other sites More sharing options...
edge Posted November 20, 2008 Share Posted November 20, 2008 I value your opinion but I think Ill try and fix this one to be honest. Didnt realise you had brought it. Quote Link to comment Share on other sites More sharing options...
Luka-P Posted November 20, 2008 Author Share Posted November 20, 2008 Didnt realise you had brought it. Lol cheers dude. For the price I paid I didn't need to think about it! Got the head off anyway and the gasket was Buffalo Joe'd. Also the end of the fast idle cable is broken, so Ill have to get a new one or new end. Quote Link to comment Share on other sites More sharing options...
Luka-P Posted November 23, 2008 Author Share Posted November 23, 2008 Did the headgasket but its still smoking. Re-lapped all the valves and put new stem seals on etc. The EGR valve looks quite bad so Ill do that tomorrow. Anyone else have any opinions? Quote Link to comment Share on other sites More sharing options...
bignum Posted November 23, 2008 Share Posted November 23, 2008 You never said what colour the smoke is,,? Quote Link to comment Share on other sites More sharing options...
merckx Posted November 23, 2008 Share Posted November 23, 2008 Injection pump timing? Injectors? Quote Link to comment Share on other sites More sharing options...
Luka-P Posted November 24, 2008 Author Share Posted November 24, 2008 I wouldnt call it white smoke, more grey, but not enough to be black. I suspect it may be worn rings, need to get it compression tested. The injectors are brand new and the pump timing was done when I did the H/G so probably not that. Quote Link to comment Share on other sites More sharing options...
